Question about EliteGroup (ECS 915PL-A2) Motherboard
No post beep, no video
I am building my own computer, the computer will turn on but, i don't hear any post beeps with the ECS 915PL-A2. the cd-rom drive works, you can hear the harddrive(sata connect) spin up. my first problem is with the post. can anyone help. thks
  • 38 Answers
Had a similar problem with a box i built. Your power supply has two connectors. One long one and a 4 pin connector. Make sure that four pin connector is connected.
Posted on Oct 25, 2007
Describe your (ECS 915PL-A2) Motherboard Problem do not detect hard disk and dvd rider in the bios
1. Check if both drive data and power cables are correctly and tight fitted.
2. If both are fitted on PATA (IDE) on the same port/cable:
The harddisk should be the MASTER and DVD the SLAVE device.
3. Recheck.
4. If not OK, Power OFF the computer (also from the wall outlet).
5. Place the mainboard jumper for CMOS RESET to the other position for a few seconds and place it back.
6. Turn the computer Power ON and check.
Aug 25, 2011 | EliteGroup (ECS 915PL-A2) Motherboard
I cannot find any sound driver for my pc....please help me
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
Apr 16, 2011 | EliteGroup (ECS 915PL-A2) Motherboard
Cannot find the SATA hard drives for my ecs 915PL-A2 mother board. All connections have been checked
Did it just stop? Or is the a new system?
Did you check your BIOS settings?
ECS is not known for excellent quality - if you have a bad board hopefully it is still under warranty.
Mar 04, 2010 | EliteGroup (ECS 915PL-A2) Motherboard
POST-Beep-Code List availible for Phoenix-BIOS? ECS 755-A2
The problem is with your RAM. Try installing the RAM in another slot. Install your AGP card slowly. I can assure about your motherboard yet you have no problem without assembling. Keep informing.
Feb 22, 2009 | EliteGroup SiS755 (755-A2 V1.0)...
No power
Make sure the cpu fan is properly placed on the processor or not !!! It might cause the problem..
Thank you......
Oct 09, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Shutdown at Windows Log-in or Desktop
Hi kpspero, I gather you can get into you're bios? Once there go to hardware monitor (page 26 in you're manual, which should allow you to watch the motherboard temp & CPU temp. You're CPU may be overheating. (Keep the case closed when checking this). Normal operation. Did you add thermal grease between the CPU & heatsink? Go to page 4 & 5 of you're manual. Check that you have connected number 21, Auxiliary 4-pin power connector.
Two more thoughts. If everything is connected correctly & you're system is not over heating, try updating the bios. Click on this link which will take you to ECS's web site for you're board.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=533&DetailName=Bios&MenuID=44&LanID=0
After flashing the bios, re-check you're bios settings. There are many updates for the 915PL-A2 MB & for windows. Did you hear any beeps from the PC during boot up? Did you connect the motherboard speaker? If you do not have a motherboard speaker you can get one from this site:
http://store.cwc-group.com/casp.html Lastly, since you can get to you're desktop, from time to time. Is this a fresh install of windows XP? Have you installed windows more than once? If you said yes to either. Download the hard drives manufactures bootable floppy disk setup software/tools/utilities & use that floppy to format the hard drive & setup the drive. Do not use windows to perform the format. Install ECS's CD software/drivers after windows has been installed.
If you're system continues to has this shut down problem, post back & I'll go from there.
Good Luck!
Mike
Jun 08, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
915PL-A2: no post, no beep, no keyboard lights
You may have a short between the board & the case. (check it).
Even if this means removing the board. That clicking you hear through the speakers suggest a short. Make sure your using (Stand offs) which keeps your board off the case's mounting surface. Check the back plate so the tabs are touching the ports comming off the board for good ground.
Double check the you have fully connected both the main power ATX_ 20 pin power connector & the auxiliary 4-pin power
connector. pg. 10. Connecting 20/24-pin power cable Remove & re-seat. If your PSU has a 20 pin connector make sure you connect the cable from the correct end.
Without POST you will not get video to load. Reset your bios
pg. 9 in your manual. Re-enter your bios and setup the bios settings for your board.
Let me know if this helps you reach POST?
Mar 14, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
ECS 915PL-A2 motherboard RAM upgrade
try to reset the cmos first so that the bios would refresh
Dec 23, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
No post, no video
get some cheap PCI card plug it in. get to the bios make sure integrated video is selected. Speaker connector is two pins in various motherboard the pins should be located close to the reset and power pins.
Oct 26, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Ecs 915pl-a2 v3.1b
Check this out http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=533&DetailName=Specification&MenuID=44&LanID=0
Oct 19, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
EliteGroup (ECS 915PL-A2) Motherboard Logo
104 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
