Each panel,door or lid is checked sensor. Under open lid seal impossible. Define, what panel is considered open. Check density of прилегания door to body of the device. Often can be so that quite little comes short that sensor was completely перекррыт. Else take a place that sensor falls out of its landing place , you should be shure that that sensor are not damaged and they mooving ease revolve. Thank you, Good luck!
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant...
(More)
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant connection (only 1) in back of tv-vcr unit and the yellow and white connections in frt of unit are connected via a cable with r-y-w to converter box and y-w to frt of tv unit. At the advance record screen..channel 3 is showing in the selection box, if you insert a different channel it will not record that channel/program. Are there any converter companies that had the foresight to know that there are hundreds of tv-vcr combos still in use? I understand the mechanics for a stand alone vcr and I know how to manually record on the combo..but I want to be able to preset and for more than one channel and recording times. Thanx
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
