iHome iBT16 Speakers Logo
A
Anonymous Posted on Feb 01, 2014
Issue with pairing
Light does not flash red and blue
My one set of Scala Rider teamset pro will not let the second set talk to it but the microphone works- any solution?
Do the 2 units pair up when you switch on ? If they do try swapping the units to see if the problem changes from one helmet to the other.
If it does then the problem is with one of the units, if it stays with one helmet then it may be a wiring problem to the speakers.If they dont pairup when you switch on try re-setting the pairing and start again. With the unit turned on, press and hold the CTRL button for 6 seconds till the light flashes red then blue rapidly then press the volume up button for 3 secs, the red/blue should flash 5 times to confirm reset done. Then re pair the units for intercom, switch both units on, when they are flashing slow blue on one unit press the CTRL and Intercom Buttons simultaneously for 6 secs so the red light flashes rapidly, repeat for the 2nd unit, they should both go to a solid red light within a few seconds then slow flash blue to show they have paired for intercom use. If this does not cure the problem you will probably have to send the units for repair.
Hope this helps
Tim
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
IPhone 4 s not recognizing the 232
Once you make your iphone discoverable, then put the Plantronics 232 headset into pairing mode by pressing the call control button until it flashes red and blue. If it's not flashing red and blue, then it is not in pairing mode. Below is a link for the pairing instructions for the 230 headset (which is the same as the 232):
Plantronics Explorer 230/232 Pairing Instructions
Good luck from Headsets Direct!
I cant pair my phone N95 8 GB to plantronics explorer 230 using 0000
It's important to follow these pairing instructions carefully if you're having problems connecting the two devices. If you have a flashing blue light on your headset, hold the button in on the headset until you see red, release it so it will turn off. Then hold in that same button until you see the light on the headset flashing red/blue, red/blue. Once the headset is flashing red/blue your phone should find the headset. If your phone asks you for a passkey, that is 0000 (4 zeroes). Hopefully this should help you.
Good luck from Headsets Direct - 800-914-7996.
1helpful
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 • Cell Phones
SUDDENLY THS MORNING THE BLUE LIGHT ON AND THE RED LIGHT OFF ARE FLASHING ALTERNATELY IE WHEN AERIAL LOCATED TO ON POSITION THE ON LIGHT BLUE FLASHES ALTERNATE RED AND BLUE AND BLUE TOOTH NOT WORKING
I think your car kit has lost its pairing data. Blue and red lights flashing alternately means it is in pairing mode. On your phone (or the device it was paired with), delete the partnership with your car kit, and make it search for new devices again. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
By the way, detailed instructions on how to pair it with your phone (illustrated with pictures) can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
3helpful
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
30helpful
2answers
Headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
31helpful
3answers
My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Top iHome Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
