Hooked up to a kicker L712. Worked fine now its in protection mode. When i turn it on the light is green for a second then turns red. It wont stay green. What should i do? Is it the circuit board?
perhaps you are pushing the amp to hard check that the gain control knob is not turned all the way up. This will cause the amp to overheat. If not that check all of the wiring to the amp for a possible short.
i have a pioneer gm-d8400m when the amp is working properly there is a blue light on the front of...
(More)
i have a pioneer gm-d8400m when the amp is working properly there is a blue light on the front of the amp that is steady on but now when i hook the amp up the light flashes and the amp wont work please help
The premium audio system in my 06 Toyota Solara skips audio in the 6 cd, radio and tape player. All...
(More)
The premium audio system in my 06 Toyota Solara skips audio in the 6 cd, radio and tape player. All 3 have the problem!. It's a JBL system. It will work okay for awhile and then I will lose sound for a second or two and then it resumes playing. I need help!!!
the yellow wire on my sony is melting and blows fuses. if I let it cool down it works fine then...
(More)
the yellow wire on my sony is melting and blows fuses. if I let it cool down it works fine then after awhile starts getting hot and melting the wire again then the new fuse blows
Can you bridge a sony xm-2200gtx amp, if so what polarity on which channel. Currently pushing two...
(More)
Can you bridge a sony xm-2200gtx amp, if so what polarity on which channel. Currently pushing two speakers. trying to see if i can bridge it and use a singe speaker?
