Question about Sun Color Entry
I have a problem with my monitor Sun GDM-5010PT!
When not connect cable from CPU to monitor, it's good. When connect cable to CPU, sometimes it's good sometimes it does not identify screen mode (polar of H-synch and V-synch signals), it mean screen is distorted.
I think microcontroller MB90550A works unstable.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Im confused?!
1. How is when NOT CONNECTED "good" Do you mean that you can see and change the configuration menus?
2. Do you have installed a VGA/13W3 adapter between computer and monitor?
3. Have you changed ie swapped out the components?
a. video card
b. cable
c. monitor
4. Sun Monitors are the ultimit plug and play calbe;
0-0.0.0 NA
1-0.0.1 Reserved
2-0.1.0 1280 x1024, 76hz
3-0.1.1 1152 x900, 66
4-1.0.0 1152 x900, 76 (19in)
5-1.0.1 Reserved
6-1.1.0 1152 x900, 76 (17in)
7-1.1.1 No Monitor Connected
Posted on Feb 11, 2008
Ibm e74 monitor is no but signals is showing one time only 2 second than Blak screen power led alos on, one time eht is on than is off
Hi.try use other monitor connect to your CPU. if it's running good problem of your monitor data cable CPU to monitor. you need to trace loose wiring or pin of cable to CPU maybe loose.
See attach picture.
Jun 18, 2011 | Computers & Internet
Tip
One thing you left out - this only applies to CRT monitors, LCD's are completely...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Jan 11, 2009 | Sony SDM-HS73P 17" LCD Monitor
Screen said please check video cable connection?
This is an indication that the monitor is not receiving a video signal from the computer. Check both ends of the video cable - both the connection to the monitor as well as the connection to your computer's video card, and make sure that both are secure. If the connections are secure and the problem persists, buy a replacement video cable. If that fails to fix the issue, try swapping out a different video card.
Mar 02, 2011 | HP Computers & Internet
When i plug to the cpu monitor cut off the power and green light is blinc
Do one think just plug out Monitor to CPU cable , just on monitor only if so can you able to see one small icon go top to bottom its like keyboard, if you can see that, you don't have any problem on your monitor.
step 1 - just remove ram slot and insert again try to ON your system now
step 2 - take your cpu and connect to other monitor and check where it getting on or not , if monitor get ON and work good mean you don't have problem with your CPU , problem was in monitor to cpu cable ,so change your monitor cable its just cost of 4 to 5 $.
step 3 - take your monitor connect to another CPU , check weather you getting same problem if it work good mean, your CPU motherboard have problem just call your hardware engr to solve it,
GOOD LUCK ! if your problem solved don't forget to rate
Dec 31, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
The power button on my LG W1934S monitor just flashes continuously and does not show an image. I have tried several cables.
try this....
remove the vga cable at the back of your monitor or at the other one in your cpu..
get it?? the one that connect the cpu and the monitor..
then try to turn on your monitor if there is a message says like this " no signal output" or no video output"..
it means your monitor is ok and you have a problem in your cpu...
sometimes that is the problem....
Feb 13, 2010 | LG W1934S-BN 19" Monitor
My Samsung syncmaster 730a monitor wont come on. the green light is solid but screen is black. could i have done something or might it have gone bad?
Hi friend,
You need you check your display cable. it should be connected in your CPU. sometime cable lose in CPU..then monitor not given any display ...
Dec 20, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My aunties monitor ,when she turn it on the monitor the power saving mode appears.
make sure data cable is connected from both end......One from CPU side and other from LCD side.
Oct 14, 2009 | LG Flatron L1750S 17" LCD Monitor
Turns ON only after a day or so of rest.
I think you have a faulty Power Supply, more than likely it is gonna be my old favorite faulty Electrolytic Capacitors, Intermittent problems are real tricky to fix, If ya handy you could try opening it up and having a squiz, look for any loose connections or "Swollen" Capacitors see if all the "Lights" are on etc, try gently "Tapping" around maybe it's a "Dry Joint" but my money is on the PSU. If ya can see a problem say Faulty Electro's replace with the same or better Temperature rating ... Good luck
Jul 30, 2007 | SGI Silicon Graphics GDM 4011P 20" CRT...
Sun Color Entry Logo
111 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
Tape-Techie
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
