Question about Sony PCGFX120 VAIO Notebook
My screen won't turn on
When i turn my computer on, the screen won't light up. i can barely see the background and everthing but the main light is off. do i need to change a bulb???   -help in ak-
    Problem Solver:
  • 16 Answers
Check the cable throu lcd, possible the cable lost contak. that was supply on the screen. re-chect all connector first before you replace the bulb.
Posted on Oct 25, 2007
Tv turns on and screen flickers on for a second and then turns off, whats the issue?
Sounds like Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
Jul 28, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Console Won't Turn On
Well try a new ac adapter to see if it makes a difference then.
Sep 17, 2012 | Sega Genesis Console
I left my lights on over night and i had got a jump on the car this moring everthing come on but the car want turn over to start. what could be wrong with it
Remove your battery and have it checked and charged if necessary then reinstall it and see if it will start. If your engine will turn over but won't start you may have damaged your onboard computer and that will need to be performed by a qualified mechanic.Hope this helps.
Jul 04, 2011 | 2004 Chevrolet Aveo
MICRON CRT MONITOR SCREEN BACKGROUND COLOR TURNED
The problem your monitor experiences is most probably a defective VGA cable. Check the monitor's cable at the place it connects to the computer. Make sure the socket does not have any bent or broken pins. Also make sure that the cable is not severely bent at the socket. If you found either of these situations, you will then need to replace the cable's socket with a new one.
Dec 20, 2009 | MPC Computers Computers & Internet
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
Screen went almost completely dark, can barely see at all.
I had a similar problem with an HP DV2000 notebook computer. Here's the solution for the HP model DV2040TX: Problem identified and FIXED. Not the screen, not the screen power supply. The problem was the micro-switch within the right-hand-side screen hinge. This switch turns off the screen when you close the lid of the notebook - probably to prevent overheating. The switch had failed mechanically (technical term: "fallen to bits"). As a low-cost fix, I have unscrewed the main casing including the screws inside the battery compartment, removed the silver panel covering the speakers, flicked the switch "ON" using a jewellers' screwdriver, and removed the small metal tongue that is operated by a cam on the hinge. Thus, the switch is PERMANENTLY ON. Computer operates normally, shuts down normally using Windows. Just need to be aware not to close the lid without shutting down the computer beforehand. Hope this helps you. All the best, OzKluger
Jan 23, 2009 | HP Pavilion dv2000t Notebook
Compaq 1701 Flat Panel Monitor Powers Up but screen is blank
no when u power up the system press F8 key then u got safe mofde menu.
then go to enable vga mode then change resolutioin to 800 *600 or 1024*768
then apply and ok.
thats it.
Nov 11, 2008 | HP Compaq 1701 17" Flat Panel LCD Monitor
MOTO Q dropped in toliet (USA)
open u mobile wash it with pcb cleaner or Petrol than heat it with SMD. if any proble contact me.
sr99mobiles@yahoo.co.in
Nov 21, 2007 | LG VX6000
Sony PCGFX120 VAIO Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
