I've noticed water leakage from SamSung split AC (1.5 ton) since last night. I realised this problem just on today's morning!
It is also noticed that lots of water coming out from the outlet tube, which was not seen earlier.
For your information, my split AC is 2 years old (approx.)
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Insert a wire from its drain to inside if it open then ok other wise take technician it will open cover of indoor unit and clean its drain because it bllocked.
