Question about Whirlpool GS6SHAXLS Side by Side Refrigerator
Whirlpool refrigerator ice dispenser no longer workds
I have a whirlpool refrigerator, model GS6SHAXLS03. the ice dispenser no longer works. water dispenser and ice maker work fine. no noise when lever is depressed.
  • Whirlpool Master
  • 4,654 Answers
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
  • 2 more comments
  • John Tripp
    John Tripp Jun 11, 2009
    Sometimes I don't get replies from Fixya. Sorry about that. I will research your model closer now that I have your email. My site ishttp://servicepartstec.blogspot.com/
    Enter model number in search box GS6SHAXLS03 and you will be able to follow with me. I am available till morning at cell # 864-812-1887 or I can call you. You also can cluck on my name below and it takes you to my site, Thanks, Sea Breeze
    Remove the Ice container and set it to the side. Press the door switch button that turns the light on in so the refrigerator thinks the door is closed have someone press the dispense ice button and look in back to see is the fork object is turning and if is clock wise or counter. Also look at the nut that the fork is mounted on to see if for some reason it has become loose. Then let me know. I did go back to your page and see that another pro said something about the module inside front of ice maker may be the reason, but we need to determine first if power is going to the auger fork first. I do have the service manual attached to this email for the ice maker in PDF format. adobe.com adobe 9 free addition will open it. I also have a whirlpool ice make trouble shooting manual I will send if this do help use get on the right track. .Sea breeze
    There were many types through the years for now w need to unplug the ice maker and examine the inside for what is in the photo. Let me know what you find.
    I'm leaning on localwonder on this one!, Sea Breeze
  • John Tripp
    John Tripp Jun 12, 2009
    Those four High Quality Photos are a great way of explain the problem and the solution will be coming as soon as I can go over the service notes and have a talk with our sponsors. In addition this is going to be blogged at another site hosted by one of the sponsors below your post. I will email you and have you also involved. This is Fixya and we all need to work together to solve our customers and not anger the other sponsors. Hope you can understand that is the way I will handle this until solved. Thanks, Sea Breeze
  • John Tripp
    RD, I still have a feeling the problem is in the control panel in the front and behind the dispenser control panel. Your blog continues below at a this link http://appliancejunk.com/forums/index.ph...
    May not work for you to enter from that link yet, but will copy and paste to your email.
    And your photos are on the web to view at this link
    http://appliancepartsandtechnicalservice...
  • John Tripp
    John Tripp Jun 13, 2009
    OK, Here is what we have from Tech Brian,
    Well JW invited me to this thread, but I am a little confused as to the is going on. The original question on Fixya stated water was dispensing and the ice maker was working, but the ice was not dispensing. This would indicate a problem with the auger motor or the wiring leading to it. I also read a reply about replacing the module which has nothing to do with the dispenser so I hope that information has been dismissed. There is no board associated with the dispenser on that model as it is simply a set of buttons that change the routing of the power to the motor. So as was mentioned, if the freezer door switch is closed, then 120vac should be read between the blue and white wires at the motor when the ice dispenser lever is pressed. If there is no voltage, then it would be time to remove the dispenser cover and check the voltage at the dispenser lever switch. If there is voltage, then the DC outputs from the motor would need to be verified to determine if the motor was the issue or dispenser selector buttons. Playing the odds, I would suspect the inverter board on the motor as failed due to water leaking down the auger coupler shaft, but that would need to be verified with a multimeter. If the customer has access to a multimeter, they will need to run the circuit and verify voltages, or they can just start replacing the associated parts. Hope this helps.
    Carefully do this test and let me know what you find, Thanks, Sea Breeze
  • 6,784 Answers
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Ice maker is not producing ice. Water dispenser is working fine. On Whirlpool Gold Model #GS6SHAXLS03
If the ice maker is not refilling with water after its last harvest that points to the=> W10408179 Water Inlet Valve. If the ice maker just sits there with ice and does not empty into the ice bucket we will need to test the 4389102 Ice Level Control
Instructions on how to test can be found HERE If you have something else happening here please let me know, Sea Breeze
If the ice maker is not refilling with water the side of the water control valve that fills the ice maker is defective and you will still get water from the dispenser. The parts I listeed above are for your GS6SHAXLS03 refrigerator.
Oct 15, 2013 | Whirlpool GS6SHAXLS Side by Side...
I have a whirlpool model ED25PWXBN00 refrig and the ice maker is making ice but the part that holds and dispenses the ice has broken and no longer dispenses ice. what part do i need?
That depends if the ice maker continues to fill with water or just sits there with the ice slots empty. Sometimes it is the dual water control valve=> 4318046 Water Control Valve
and sometimes the ice maker itself. Does not hurt to have an extra part of each if you are a ice user like myself. If ice slots are empty fill with tap water and allow to freeze. If the ice drops and slots do not refill with water then replace the dual water control valve. 4317943 Ice Maker Assembly.
Oct 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool ed5phexrb00 icemaker no longer works
Ice maker does not seem to have water flowing to it.
Mar 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool side by side refridgerator about a year or more ago the water dispenser stopped working and now the ice cube dispenser also stopped working it is no longer making ice into the container....
Your water line into the refrigerator is probably plugged up. First, check at the cut-off valve where the house water connects to the refrigerator water line. Mineral deposits often form in these small valves and can block the water flow.
The other possibility is a blocked water line within the refrigerator. Plastic weedeater line works very well to clean out these lines.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
May 25, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Ice maker not working ; water dispenser ok
The reason could be several different possibilities. the water control valve for the ice maker no longer works or one of the many components inside the ice maker is needing replace or adjusted. Go to link below and enter model ED5VHGXM into model search. Click on photo #12 ice maker and you get a breakdown of of all the parts. Let me know, Sea Breeze
May 18, 2009 | Whirlpool ED5VHGXM Side by Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Open Questions:
Whirlpool GS6SHAXLS Side by Side Refrigerator Logo
1,668 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
