Home | Viking | 24 in. Professional Series VUD141 (Ul... | NO POWER TO THE MACHINE
Viking 24 in. Professional Series VUD141  Built-in Dishwasher
Problem for Viking 24 in. Professional Series VUD141 (Ultra-Premium)...
By stilden on Jun 05, 2009
I have a 7 year old Viking built-in dishwasher and when i went to turn it on it does nothing. There is water left in the bottom of the dishwasher but there is nn power to the unit. The breaker is fine. Is there some kind of reset button. I have pulled the unit out of the cabinet and can see no apparent problems. Any ideas?
Sponsored Links
Solution #1
posted on Jul 04, 2009
Somewhat Helpful)
PCmania
Rank: Wiz
Rating: 83%, 261 votes
Hi...
Good luck !!!
Regards
PCmania
Was this helpful?
Yes
No
Solution #2
posted on Jun 05, 2009
Not Rated)
justaskjoe
Rank: Guru
Rating: 85%, 1841 votes
Hello. I can help you. Since you already checked out the power, skip that step and look at the latch.
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Was this helpful?
Yes
No
Popular Solutions for Viking 24 in. Professional
Questions and Unsolved Problems for Viking 24 in. Professional
Do you recommend Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher?
Answer
Answer
water was shut off during dishwasher cycle not dish water will not work no water even though water... (More)
Answer
Viking dw 20.3 does not complete cycle or open soap door. It does drain and fill ok . When it stops... (More)
Answer
viking dishwasher sounds like it's running but doesn't actually wash. It will empty water if I put... (More)
Answer
our unit sounds like it is running but the wash feature never turns on. when the power switch is set... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Viking 24 in. Professional...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
