Question about HP PSC 2210 All-In-One InkJet Printer
Problems on paper jam (just after the selftest)mode switches blinking
Good morning,
I come across the problems , when ever switch on the printer , after the self test directly blinking all the mode switches and giving message papper jam .( with or without paper on tray)  with noisy sound like broken gears. could you suggest, what to do for solving this problems.
  • Anonymous Apr 23, 2008
    paper threading through printer crooked
    Problem Solver:
  • 14 Answers
You may have to reset the printer. I believe these are the directions to follow:
Re-initialize the HP All-in-One Force the HP All-in-One to reinitialize by following the steps below:
  1. Turn the unit off by pressing the ON button.
  2. Disconnect the power cord.
  3. Wait five seconds, then reconnect the power cord.
  4. If necessary, turn the unit back on and try reading the photo card again.
  5. If the unit fails to read the card again, reset the All-in-One. Repeat Steps 1 – 4, but before plugging the unit back in, press and hold the # and 6 keys on the HP All-in-One numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the All-in-One reestablishes communication with the computer, reset the language and country/region.
Posted on Jun 13, 2008
Why there is continuous blinking of power switch and not giving self test hp d2460?
Please all connect cable and adapter disconnect and some time wait and proper connect all cables. Connection after if solved then ok other wise toner removed and reconnect, dust clean or reinstalled driver.
Read More support .... HP Printer Support
Thanks,
Jul 14, 2014 | HP Deskjet 2460 InkJet Printer
I am asking this question for my son. His power went out and now his printer when you turn it on blinks blue and will do nothing else. Is there something we can do?
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer, using the instructions below. (Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.)
First, please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the gray button is pressed? If not, you can stop here and write back to let us know and we can give you further instructions. It's most likely, however, that the power-on and form-feed will work fine.
Next, try this printer self-test by following the steps given below:
1. Press the "Menu" button to escape "Photo Mode."
2. Press the "Down Arrow" until the screen shows "Print Test Page."
3. Press the "Select" button to print the Test Page.
4. The test is not continuous.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously).
Should this test fail, remove both cartridges and try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, you may have a paper jam, or the printer may require service.
Remove the paper from the printer and check for any obstacles (pens, thumbtacks, paper clips, etc.) or other obstructions. If you don't see any, disconnect the cables from the printer, turn it upside down and gently shake it to see if anything falls out. (Be careful to hold the cover shut during this procedure, and don't look up into the printer while you're shaking it.) In the event nothing comes out of the printer, you may require service to the printer. Stop here and let us know if this is the case, and we can provide you with further instructions.
If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
However, you may have to clear the NVRAM to resolve this issue. Please follow the steps given below:
3. Press the "Up-Arrow" and "Menu" Buttons at the same time.
4. Press the down arrow until the LCD displays "Clean NVRAM."
5. Press "Select" The LCD should display "Success" or "Failed"
Oct 01, 2009 | Lexmark P315 InkJet Photo Printer
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
May 06, 2009 | HP LaserJet 1018 Printer
A/C won't work 03 Acura RSX
General Troubleshooting Information
How to Retrieve a DTC
The Climate Control Unit has a self-diagnosis function. To run the self-diagnosis function, do the following:
1. Turn the ignition switch OFF.
2. Tu rn the fan switch OFF, the temperature control dial to MaxCool (60.F or 18.C), and the mode control dial to Vent.
3, Turn the ignition switch ON (ll),then press and hold the recirculation control switch. Within lO seconds while holding the switch down, press the rear window defogger switch five times. The recirculation indicator blinks two times and the A/C indicator comes on, then the self-diagnosis will begin. About 15 seconds later, the self diagnosis will finish and the Ay'C indicator goes off. lf there is any problem in the system after finished self diagnosis, the recirculation indicator will blink the Diagnostic Trouble Code (DTC) 1 through 13. When problems in the evaporator temperature sensor circuit are detected (codes 14 and t5), the A/C indicator will blink the DTC. lf no DTCs are found. the indicator will not blink.
d35f123.jpg 695f305.jpg5d11822.jpg Resetting the Self-diagnosis Function
Turn the ignition switch OFF to cancel the self-diagnosis function. After completing repair work, run the self-diagnosis function again to make sure that there are no other malfunctions.
Jan 13, 2009 | 2006 Acura RSX
Blinking jam lite. The instant of power.
The service mode is a little bit primitive on that machine for testing switches.
You can visually inspect the problems on that machine.
Jun 10, 2008 | Sharp AL 1631 Copier
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
3com 3300 TM - all Ethernet port not working, power led flashing
A blinking power LED means that the switch is either downloading software, or is initializing which also includes running the Power On Self Test. You may have firmware issues with the switch and/or the switch is stuck in initialization mode. You may have to contact 3com regarding a warranty issue. Hope this helps. Good luck.
Nov 20, 2006 | 3Com SuperStack 3 3300 TM Networking...
HP PSC 2210 All-In-One InkJet Printer Logo
52 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
