After 3 seconds of reset (start), turn the dishwasher off, wait a few secconds, turn it on, and use the arrows to select the washing mode (try Auto, perhaps) and see if this solves your problem.
you can get the trouble codes out by turning key on off on off on then watch the check engine light it will flash a number of times n pause this will give you codes to take to the auto parts store n tell them they will know most of them the service writer at the dealer can find the rest (example) blink blink blink pause blink blink =32 there could be several so do it a couple times to make sure you get them right and get them all
If any of the gauges are blinking and going haywire and the security light flashing then the instument cluster is faulty.But if it is just the security light flashing then its in the switch.If you only had the switch replaced then you need a new ignition lock cylinder because its worn out.
check switch connections,fluid level and actuator at transfer case if good have truck scanned for possible trouble code possibleas sensor or component going bad , some auto stores such as auto zone /advanced auto do it for free if theres a trouble code it will be a starting point
