Question about Compaq FS7550 17" CRT Monitor
Video display I have 2 boxes coming up on my screen intermitantlyone is a rectangle with what looks like a red circle with half solid red on one end and then bars and 100% written under itthe other is a blue square with the same red circle at the top and whiteoutlined icons in a circle then an exit square on top next to the circle In the center is written--user mode- or- 800x600-then- H:37.8K-then-V:60HzBoth are tight against the screen and the curser goes behind themIt is not a virus or anything like that--I have been scanned and rescanned. It has to be the monitor or computer. Some weird things, like settings changing,have been happening in properties displayThis is driving me crazy--hope you can help
  • 1 more comment
  • Oil painter Oct 25, 2007
    2 payments NO HELP what a crock. Didn't even talk to silver dragon. And the Gskellig tried but couldn't help. You won't get me back here again.
  • Anonymous May 02, 2008
    Problem Solver:
  • 14 Answers
Sorry I couldn't help you, I think this is your best bet. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&dlc=en&product=217312&lang=en
don't know what happened, the fixya chat closed itself... you can email me at gskellig@gmail.com if you need help with that other problem. =\
Posted on Oct 25, 2007
SOURCE:
My laptop screen goes blank but i noticed that my computer is still on and i have to put it in a certain angle for the screen to go back on, is it because my hinges are loose?
might be a loose lead or bad connection if your hinges are loose tighten them up also
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
hope this helps you:
Sep 08, 2011 | Computers & Internet
If you know about area formulas of class 8 and 9,please solve my question?there is a circle.in the between of the circle,there is a rectangle of dimension 4cm and 3cm.if the rectangle will cut out what...
The diameter of the circle is the diagonal of the rectangle use Pythagoras this rectangle is a made from two 3,4,5 triangles, so the diameter is 5cm, the radius will be 2.5cm don't forget the BODMAS ordering rule (Brackets of Division Multiplication Addition and Subtraction) Also rounding to 2 decimal places. This solution is based on all four corners of the rectangle touching the circumference of the circle.
Area of a circle is P (22/7) i x Radius (squared ^2) ====> 22/7 x 2.5cm ^ 2 ====> 22/7 x 6.25cm
TOTAL AREA of CIRCLE = 19.64 cm^2
Area of the rectangle is length x width ====> 4 cm x 3 cm
TOTAL AREA of RECTANGLE = 12 cm ^2
The remaining portion is the circle area minus the rectangle 19.64-12 = 7.64 cm^2
SIMPLES brought to you by SpideRaY @ http://www.windowstipsclub.com
Jan 31, 2011 | Computers & Internet
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Montior screen is half shaded and half bright
Do this to check if your monitor is in working state or not...!
Step 1:- Turn on your computer.
Step 2:- Unplug the Video Cable of your monitor which is connected with the computer.
( Video cable:- Cable going from the back of your monitor to the back of your tower. It has a plug with two screws on the plug ends, which you can unscrew to unplug it. Thats how it looks like. Some times it is in grey in color some times in blue.)
Step 3:- Now check on your monitor. If the display says " No Input Signal " :- your monitor is fine. Some thing wrong with the computer graphics.
If there is not display and the monitor light is blinking or solid the monitor has gone bad.
( Note :- Remember when you unplug the video cable do not unplug the power cable of the monitor. )
Let me know if it helps.
May 18, 2010 | Computers & Internet
Decora 6124H Timer
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
Wall paper is displayed however not the PPT or Icons
You need to configure your video card.
I'm assuming this is a laptop you are working with. Go into the video card properties, and make sure the VGA port that drives the projector is not set to extend your Windows desktop.
From your desktop, right-click and choose the "properties" option.
In the Display Properties window that comes up, select the far-right tab "Settings".
See the rectangles labelled 1 & 2? Click on the rectangle with the 2, and then look down near the bottom where you'll see a checkbox with "Extend my Windows desktop to this monitor."
Make sure this box is not checked (it most likely is right now, and that's the source of your problem).
Mar 29, 2009 | Epson Office Equipment & Supplies
Compaq FS7550 17" CRT Monitor Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
