Question about Clarion VRX745VD Car DVD Player
Power I NEED TO ORDER THE RED RIBBON, WHICH GIVES THE FACE PLATE POWER.OPENING AND CLOSING TOO MUCH CRACKED THE RIBBON.I NEED TO KNOW THIS RIBBON PART NUMBER SO I CAN ORDER ONE. CAN YOU HELP, THANK YOU IN ADVANCE. E.G
  • 1 more comment
  • Elias Nov 29, 2007
    i have the same problem opening and closing has cracked the red ribbion can anyone help me??
  • Crazyfilez Aug 31, 2008
    I have the same problem too much wear and tear on the ribbon to power on the Clarion VRX745VD and also i need the right side components of the movement for the dvd fixed can you help me please
  • mandip69 Jan 25, 2009
    Clarion Part Number: 039240900
    buy it from pacparts.com
Posted on Jan 25, 2009
I have a vrx755vd need part # for the face plate power ribbon
Posted on Dec 12, 2008
You can get a new ribbon at pacparts.com. they seem to be reasonable on price too. I had the same problem but now I am having a hard time putting in the one side of it.
Posted on Jun 19, 2008
Kenwood KRC 535 - Faceplate stops halfway when turning off unit. When unit on it will play music, but nothing lights up so you don't know what you're listening to. Also cannot change station. ...
There is a fine ribbon cable that links both the main unit and the face plate. Due to the constant movement of opening and closing some of the conductive tracks develop cracks. That is the reason why when it closes half way it looses contact and the motor stops turning. The display illumination track must have completely broken.
You will need professional help to replace it because its a little complicated to access this ribbon cable.Will cost you about 15$ plus labor.
Jul 14, 2011 | Kenwood KRC 535 Cassette Player
Faceplate is not displaying anything.Knobs are ligthing up but no display.What could be wrong?
You have not mentioned how old it is. Some older models of Pioneer and Kenwood use a flat ribbon cable between the face plate and the head unit. Due to the constant opening and closing of the faceplate the ribbon develops a crack and you loose display or some times some functions.Will need professional help to replace the above.
Mar 08, 2011 | Kenwood KDC-MP635 CD Player
When I hit the 'open' button the face continues to cycle
ribbon tape sounds bad. it goes from the units main board to the detachabel faces rear mounting plate , u can inspect it for cracks , most of the time theyre visibel from looking under the unit while face is open
Oct 17, 2009 | Pioneer Car Audio & Video
My pioneer deh-p8450mp is opening and closing/switching on and off contiuously. help
Hey sparrow, sorry you didn't get an answer to this sooner, mine just started doing the same thing. After fidling and dismantling for an hour or so I think I have diagnosed it to being the ribbon cable which comes from the circuit board to the front most control panel is cracked (i.e. the cable that connects to the connectors on the removable face plate) When the panel attempts to open fully the ribbon cable is flexed enough to lose connections making the unit think the faceplate has been removed and so attempts to close...when it closes the connectors retouch causing it to think it needs to reopen....this is a nasty design flaw for a unit that cost me $1500 (admitedly 10 years ago but it was in a box in the cupboard for 8 of those years) !!!! Now any chance I can source this $2 part .....eek
Oct 03, 2009 | Pioneer DEH-P8400MP CD Player
Ribbon cable broken and now cannot open the face plate
You need to take the unit apart to fix the cable since the other end of it plugs into the board inside, it's pretty easy to take apart though. Good luck!
Feb 09, 2009 | Pioneer DEH-P8600MP CD Player
Freezes while i press open
first check all of your power and ground connections and be sure your battery is good then try the small reset button on the front face. if that does not work you may need a new flexible ribbon cable that you can find on ebay cheap.
Nov 25, 2008 | Pioneer DEH-P9600MP CD Player
Power to stereo none to unit
There is a ribbon cable that goes from the display to the main board of the radio that may be bad, if you have everything connected properly and all you get is the red led, this is a possibility. No way for anybody to know if you have it wired wrong if they can not look at it themself.
The red wire is for power when the key is on, the yellow wire should get power all the time, the black wire is ground.
If you have those correct, the radio should at least turn on. If you have these right, you may need a new ribbon cable. The connector that interfaces with the detachable face must also be taken off the old ribbon cable and put on the new one, or get a new connector and just replace it. The ribbon cable does not come with that connector. It is soldered on the ribbon cable, so if you are not very good with a soldering iron, you should have a service center do it for you.
Let me know if you want the part number for the ribbon cable and/or connector, I can get those for you.
I can not guarantee that the ribbon cable is the problem, or that it is the only problem, but it is the most likely problem with that model number of Kenwood. I have repaired many of them, so I have a good idea what causes most of the problems, but I have seen times when the usual suspect is not the problem and something else like the LCD in the face is bad, or the IC that controls the display is bad. Even a voltage regulator on the main board of the radio can be at fault as well. There are probably about 10 different things that can cause that one problem, having an experienced technician is always the best way to determan the problem with certainty.
Let me know if I can be any more help for you.
Dave
Jul 22, 2008 | Kenwood KDC-MP528 CD Player
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer powers off when face plate opens.
My first guess would be that the ribbon cable between the flip face and the mother board has gone bad. This is a very, very common problem. I'd suspect that above everything else at this point.
Jan 03, 2008 | Car Audio & Video
Clarion VRX745VD Car DVD Player Logo
358 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
