-   Inadvertently, I click on high resolution setting, since that I have No picture but I do have an audio. Any help or suggestion would be nice.-   ccsworks
Feb 21, 2009
-   no picture, no audio just rectangle paterns crossing the screen. changed inverter t501045.00mss. no fix.-   gtfmt
Nov 26, 2008
-   i have same problem. i find if i keep turning it on and off multiple times the picture will eventually come on. Usually takes about 5-10 times, however.-   Guest
Sep 09, 2008
-   I had the same problem and found that the fix posted below does work. I was able to fix the TV at a cost of about $90. It works as new now.
go to www.lcdparts.net replace the backlight inverter... costs about $90 delivered... works great...very easy to install-   dworrell
Jul 23, 2008
-   I turn on the lcd and get a piucture for about a couple of seconds and then it goes off...I still have the sound. I took it to my local electronics shop only to be told they couldn't get a "PCB Assembly" help-   rmangam1
Was this helpful?
Yes
No
Solution #2
posted on Sep 01, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Many fewer problems if you plug the tv power cord into a separate outlet without using a power strip. Also use a strong local station with volume turned up a little.
i have a dell w1700 and when i click the power button it flashes the yellow/orange light then it...
(More)
i have a dell w1700 and when i click the power button it flashes the yellow/orange light then it goes away the screen does not turn on and the buttons do not do any thing
My monitor is all black, no picture. I checked all the cables and power inputs. I tried it on...
(More)
My monitor is all black, no picture. I checked all the cables and power inputs. I tried it on another computer. It worked just fine yesterday. Any suggestions??
hi evey time i turn my dell w1700 off it keep coming back on .i check the adapter the volt is only...
(More)
hi evey time i turn my dell w1700 off it keep coming back on .i check the adapter the volt is only 15.3v it should be 16v will this make it come on in about 5 min. ty
power button is on, but it does not show anything on the screen, We plugged it into the cable line...
(More)
power button is on, but it does not show anything on the screen, We plugged it into the cable line as well and the same thing occurred. Any suggestions? It was made in 2003.
YES, I PAID CLOSE TO 600.00 A FEW YEARS BACK FOR THIS UNIT. I HAVE AUDIO, BUT A BLACK PICTURE. I THOUGHT MY KID HIT A BUTTON ON THE REMOTE CONTROL AT FIRST, BUT THE SREEN IS DEAD. WHAT A JOKE!! I AM NEVER BUYING A DELL PRODUCT AGAIN!! DOES ANYONE HAVE A CHEAP FIX, OR SHOULD I JUNK IT?
same problem here no video after a few minutes but audio is still there.One forum suggested a cooling fan addition to the top of the unit, I am waiting on information as to where and how to install, they seem to beleive it is overheating and shutting down.this is who i got my info from, mailto:pcmodderz@pcmodderz.com
I have a Dell W1700 and after only three years the screen has blacked out. Everything else is working fine. I contacted three different repair shops in the greater Seattle area and all have said they connot repait the TV because they cannot get parts. I contacted Dell and they will not repair the TV. They offer a 19 inch TV as a replacement for a cost of $399.00. IN my oppinion Dell has sold an unreliable procust and are nopt standing behind it. They no longer carry the W1700 and it makes one wonder why. My guess would be that there has been a lot of they units failing after two or three years so Dell has dicontinued them. The replacement option of a 19 inch TV for $399.00 is outragious, especially when you consider that in the current market you can buy a number of different 19 inch TV's for under $399.00.
Comment by Guest, posted on Nov 01, 2007
their is sound but no picture screen is black
When I turn it on, the picture comes on for a moment and then it blacks out but I can still hear the audio perfectly. Help?
