2 Way Radios
Problem for 2 Way Radios
Generic problem for all 2 Way Radios
How to install echo board in uniden pc6...
By glasstube on Oct 25, 2007
how to install echo board in uniden pc66 cb radio
Best Solution
posted on Oct 25, 2007
Very Helpful)
Benimur
Rank: Guru
Rating: 88%, 3779 votes
You have to cut the microphone line and put the echo board in between. The INput of the echo board should go to the end that goes to the microphone connector, the OUTput would go to the wire that leads to the CB board.Connect also the B+ and ground. The B+ should go to the switched B+ of the radio while the negative can go to any grounded area.
Good luck and kind regards.
Was this helpful?
Yes
No
Popular Solutions for 2 Way Radios
Questions and Unsolved Problems for 2 Way Radios
Answer
need info on motorola radius p60
Answer
need operating instructions for bellsouth 1008 walkie talkies
Answer
Mdl FW13z Bell South 2 way wrist radio, were can I find info on this item.
Answer
hola estoi buscando el manual de walkier midland lxt322 14 miles mi correo es... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For 2 Way Radios:
Top 2 Way Radio Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more 2 Way Radio Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
