Question about Sharp EC-6312P Bagged Canister Vacuum
Vacuum EC-851 I have Sharp vacuum cleaner EC-851. Prob;em with switch. Any service personnel at Chennai, India. Reply to
  • 1673 Answers
SOURCE: sharp upright vacuum EC-12SXT5
The inlet by the brush roll may be clogged. Alot of times the hose may be clear, but the inlet catches debris and clogs it. Did you drop something down the hose and did it dome out the other side? But if you unhook the hose and there is suction at the hose end, then it should be clogged in the inlet.
Posted on Feb 14, 2008
SOURCE: Sharp Twin Energy EC-T2840 - no suction
no sound - sounds th like the motor is frozen. this type of vac pulls the air threw the bag so by time i it gets to the motor the air is clean, unlike older vacs. it is possiable as well that a wire to the motor has become disconected. (unlikely) has the vac gotten wet at all or have you vacumed damp areas? it would be the only thing i can think of to lock up the motor. another good test and maybe the first is to take of the belt the brush might be bad and stoping the motor from spinning.
Posted on Sep 26, 2008
  • 1605 Answers
SOURCE: manual or parts list needed
you can get the parts listing form the following link
Posted on Apr 14, 2009
  • 272 Answers
SOURCE: I need to bay a belt
They have them at vascumn cleaner outlet:
There is only one for all uprights made by sharp and another for the power nozzles.
Posted on Jun 03, 2009
  • 39 Answers
SOURCE: I need to replace the belt on my Sharp Vacuum
i have replaced vacumm belts before .. Normally it is located underneath..flip over the vacumm unscrew some screws.. open the cover..youll see a large roller pin type object remove it carefully noting how it is placed..pull it out.. and replace the can also clean off the debris while doing added plus..for vacumm maintenace..
PLease indicate whether this has helped you at all ..Thank You
Posted on Jul 05, 2009
  • 5 Answers
Posted on Jan 21, 2011
0 characters
1 Points
Need new cord model EC - 12TWT4 Where we buy part store?
I just found this site when looking for parts for my EC-12TWT4. I haven't dealt with them before however...
Aug 10, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
My Sharp Vacuum, Model EC-S2365 just stopped working in the middle of vacuuming. I'm not sure what happened and I can't turn it back on. Any suggestions?
Just before it shut down were you pulling on the cord? For it to shut down like that it almost sounds like the electric cord has a break in it-probably at the plug
Jul 14, 2009 | Sharp EC-S2365 Upright Vacuum
Jun 03, 2009 | Sharp EC-S2365 Upright Vacuum
How can i keep the belt onmy sharp vacuum
If you have a rug that has tassles or open bits of "carpet tassles," this will injur ANY upright vacuum cleaner. Best way to vacuum a rug is to use a hose with a suction only floor head or small tool on the end.
Jan 29, 2009 | Sharp Twin Energy EC-T2630 Bagged Upright...
No suction on the EC-T5980
Check the inlet by the brush roll, it may be clogged.
Dec 09, 2007 | Sharp Twin Energy EC-T5980 Bagged Upright...
Sharp EC-6312P Bagged Canister Vacuum Logo
64 people viewed this question
Top Sharp Vacuums Experts
Richard Roth
Richard Roth
Ryan S
Ryan S
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
