Toshiba 1360 Black and White Copier Logo
Anonymous Posted on Oct 25, 2007
Toshiba 1360 C7 Error Code
After pressing down the clear/stop and 8 keys on the control panel, the copier shows C7 error.
  • Anonymous Sep 02, 2008
    Finally, I gived up because the machine was too old and it was better to throw it to trash.
CheckitRight
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Toshiba Master 1,363 Answers
  • Posted on Oct 25, 2007
CheckitRight
Toshiba Master
Level 3:
Renaissance:
Answers
1363
Questions
Helped
646588
Points
2795
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
What does an error c7 means in toshiba photocopier 1360 ?
C7 could be nothing serious but it had to of happened three times before it quit resetting itself, which means it has happened to you before. This model has a tendency to throw this code for no real threatening reason, but it is there as protection for the copier and it's environment. You really should have a tech look at it for you, and not just reset it.
Switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
2helpful
2answers
Canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Toshiba 1360 C7 code. How expensive is it ti fix
With the unit off hold down clear/stop and 8, ad should apear push 89 start (display will read 03) then 0 start. tis should fix it. -Carl
1helpful
Toshiba 1360
Did you replace the cleanerblade?
Power off the machine, switch on while pressing 0 & 8, enter 200, then press the start button, the machine will run for about three minutes to adjust the Toner sensor. The machine will stop, press the interupt button to save the setting, switch off and then on.
If the older techies is reading this, please help to confirm.
6helpful
2answers
Toshiba 1360 copier
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
C7 error???
Turn on the power holding 0&8, key in 89, and press print. A 3 will probably be displayed. Key in 0 and press start. Recycle power.
2helpful
Error c7
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
3answers
Toshiba 1360
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
