Blenders
Problem for Blenders
Generic problem for all Blenders
How to install replacement part
By clevergal58 on Oct 25, 2007
I have a Krups blender and a replacement part I don't know how to install.  It's the gray rubber knob with teeth that the motor turns which fits into the thing  that turns the blades.  the new part has a threaded center, and obviously fits on a threaded serw, but I don't know how to remove the old one.
Comments:
Dec 31, 2007
- I got no help from this site at all. Only this one response from someone who may know how to fix the problem but can't write well enough to help me.
Same Problem
May 21, 2009
-   I have same problem with Krups blender-   Guest
Mar 28, 2009
-   I have a krups 574 blender. The male part of the gear that inserts into the jug is made of rubber and was shaved off one time when the jug was not properly attached before the blender was turned on. I would like to order the part which I believe is $10 but I believe I need to undo the screws at the bottom of the blender to detach the gear. The screws seem to require a special tool. How would I locate such a tool?
-   p24
Mar 14, 2008
-   when i was blending smoke came out from motor part-   Guest
Jan 25, 2008
-   I have the same problem! How do I remove the old grey rubber?-   Cecilie
Best Solution
posted on Mar 18, 2008
Very Helpful)
toftinoff
Rank: Apprentice
Rating: 100%, 1 votes
Well our krups type 575 just went on the blink aswell. So I thought I'd take a look inside .I started by unplugging unit and removing the 4 rubber spacers, then removing the torque (# 20 Torque with hole in center screwdriver) Then I placed thin flat screwdriver through the slats in the bottom keeping the motor from rotating ,thus I could unscrew the rubber knob with teeth counter clockwise .So finally could remove outer casing .It seems the print out board on ours is fried so I hooked the power source directly to the motor and reassembled . Now it blends fine only one speed ,fast ,it is turned off and on by the switch on the wall. Hope this can help in some way good luck.
Was this helpful?
Yes
No
Solution #2
posted on Mar 02, 2008
Very Helpful)
dukenoid
Rank: Apprentice
Rating: 100%, 4 votes
There is a slit in the middle of the bottom of the blender. You turn the gear drive until the metal slot in the shaft lines up with the slit. Put a flat head screwdriver through the slit into the slot in the bottom of the shaft. Now hold the screwdriver to keep the shaft from turning and remove the gear drive. It took me a few tries, but it finally came loose.
Was this helpful?
Yes
No
Solution #3
posted on Dec 28, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
brush shuld shange
Solution #4
posted on Jan 10, 2008
Very Helpful)
fixeditma
Rank: Apprentice
Rating: 100%, 2 votes
You need the remove the old gray rubber knob. I did it in a barbaric way just hacking at it with scissors. Once you've removed all the rubber, you can use pliers to remove the remaining metal base. Once that's removed, place the new piece on the post and spin it on. Most important, spin clockwise to loosen, not counter clockwise like most items.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Jun 01, 2008
Not Rated)
drt238
Rank: Apprentice
Rating: 0%, 0 votes
The old gray rubber part is left-handed threaded. To remove it just turn it clockwise like you are trying to tighten it. You make have to take the bottom of the blender so the wheel doesn't turn.
Was this helpful?
Yes
No
Popular Solutions for Blenders
Questions and Unsolved Problems for Blenders
Answer
pour spout broken on back to basic sp smoothie 600
Answer
I have bought a replacement jar (the old one broke) and I can't fit the blade assembly into the... (More)
Answer
We need to replace the plastic pitcher.
Answer
I do not find a reset button on the bottom of the Bosch Universal Kitchen mixer. Is the button... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Blenders:
Top Blender Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
