Question about Logitech Quickcam Zoom 5 Pack Webcam
Windows Vista Doesn't anyone know how to make my Logitech Quickcam Zoom work with Vista???? Is there a patch??? Is there a possible upgrade, or driver???? Please help.....
My logitech worked sevearal months ago, now it won't. So my solution, I smasched the m other ph ucker. It still don't work, but I feel much better.
Posted on Apr 08, 2012
Http://www.softwarepatch.com/utilities/logitech-webcam-driver-quickcam.html
Try these, it works for me on Ultimate after a bit of compatibility tweaking (a lot of it on my account as I messed up the install and had to clean up the mess)
Try it out.
Posted on Dec 27, 2007
I lost the cd to my quickcam 8.4 and cant install it on my new pc
found the following link for the Quickcam Zoom 8.4 software, but it shows that it only supports Windows 98, ME, 2000, and Xp ... there are no supported drivers/software for Vista or Windows 7. So if that is what is on your new PC then you will most likely need to get a new Cam or Contact Logitech directly to see if they have plans on releasing software for this cam for newer operating systems.
http://www.logitech.com/pub/techsupport/quickcam/qc848enu.exe
Good luck.
Apr 01, 2010 | Logitech Quickcam Zoom 5 Pack Webcam
Will the logitech quickcam stx work with windows 7
No, you can install it now. There should be no issue with upgrading later.
Only thing I would suggest is that you check if the webcam is compatible with Windows 7, but I think almost all Logitech webcams are, so no issue.
Dec 28, 2009 | Logitech QuickCam Communicate STX Personal...
Logitech quickcam pro 9000 video - does not work,
http://www.camera-drivers.com/companies/605.htm
if you take a look on this site ..you will see that all logitech drivers are built for windows xp..at the top...so.....if you are running vista or more...you will need a suitable driver for that ..built for vista or patched..( if so ..is understandable why it works in another pc with xp on)
if this isnt the problem and you either have a vista compatible ...or are running xp on your machine ...its probably something related with your usb ..
ity might also be ..so me driver related...I had someproblems once ...after I adapted a videocam ( digital) to work as a web cam ...and it needed a special program to do that ...some capture program ....after i uninstalled that ...I wasnt able to run a normal webcam ...cause it was already messed with my system files and it was asking for that frogram to run ...the solution in that case was to reinstall the operating system ...as a last resort you may try just that ...( it will fix any possible usb driver related problems too)
Apr 15, 2009 | Logitech QuickCam Communicate STX Personal...
QuickCam Zoom not working after upgrade to Vista
Just read the most wonder article on how toe fix your quickcam zoom for vista follow these steps
These is from 2007 post so you will have to google for the drivers mentioned. I did and it worked
I have a Logitech Quickcam Zoom and this is how I got it to work:
1. Install QuickCam 32-bit Version: 10.5.0 Build 1096b
It can be found here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=10234
2. When you get to the camera detection part where it asks you to plug in your camera, plug it into a new usb port (if you had it plugged in when you installed Vista) and just press skip.
3. Windows may try and find the driver for it, you can cancel that too.
4. Install the old QuickCam software (Version: 8.4.8 build 1034A)and overwrite anything it asks you to (it will fail to install completely because of the new version, but it will put the files you need into the Logitech program files directory.
The old software is here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=7649
5. Go to the windows orb (former start button), open control panel, go to system, then on the top left of the window click device manager.
6. Find the unknown usb device (hopefully you only have one... otherwise unplug anything else that doesn't work or you haven't updated the driver for yet)
7. Right click and select update driver, choose a location to find the driver, navigate your way to C:\Program Files\Logitech\QuickCamWebInstall\Drivers\WinNew\PRO2
8. Press OK or whatever, and let it install.
9. Enjoy!
Mine didn't even need to reboot and worked with the 10.5 QuickCapture software. Still need to test with Skype and Live Messenger though.
Jan 08, 2009 | Logitech Quickcam USB Zoom Webcam
Logitech quickcam zoom with vista?
I haven cheked this ,
this is a patch to make your webcam compatible with vista.
try this
http://www.logitech.com/pub/techsupport/quickcam/qc1150.exe
i m sorry if it doesn work becos i don ve the webcam to check wit the patch
Sep 20, 2008 | Logitech Quickcam Zoom 5 Pack Webcam
QuickCam and Vista
Sorry to inform you but this camera will not work with Windows Vista, that's why its not recognize by your vista computer and logitech dont create any spoftware for this to work with vista , you can also find that statement from logitech site http://www.logitech.com/index.cfm/480/3359&cl=gb,en?softwareid=697&osid=13
Hope that helps..........
Sep 07, 2008 | Logitech QuickCam Pro 3000 Webcam
Windows vista home premiun
Please click on the link mentioned below to download the drivers:
Windows Vista Multilingual 32-bit
* Title: QuickCam v11.1.0.2030
* Software Version: 11.1.0.2030
* Post Date: 8/7/2007
* Platform: Windows Vista
* File Size: Approximate download size is 30.7 megabytes.
http://www.logitech.com/pub/techsupport/quickcam/qc1110.exe
Windows Vista Multilingual 64-bit
* File Size: Approximate download size is 36.3 megabytes.
http://www.logitech.com/pub/techsupport/quickcam/qc1110_x64.exe
Also visit this website:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/LOGITECH/Logitech-QuickCam-Pro-4000.shtml
Thanks
Aug 22, 2008 | Logitech QuickCam Messenger Web Camera
Quickcam want work
Check for driver updates on the Logitech homepage, make sure that you download the driver for the specific model of your camera. Maybe the old driver is not windows vista compatible.
Aug 20, 2008 | Logitech QuickCam Pro 5000 Webcam
Haveing trouble installing logitech quick cam onto my comuptor thats running windows vista
This problem was caused by a compatibility issue between Windows Vista and Logitech QuickCam Messenger.
Logitech QuickCam Messenger was created by Logitech, Inc..
Recommendation
To search for similar devices that are compatible with this version of Windows, visit the Windows Vista Hardware Compatibility List website online.
However, it’s not totally out of hope for owner of Logitech QuickCam Messenger who has upgraded to Windows Vista. The following hack will use Windows XP driver (a common trick to use non Vista compliant device) to install the webcam in Vista:
  1. Download QuickCam 8.4.8 with driver for WinXP.
  2. Install WinRAR if not already installed yet.
  3. Open the setup installer qc848enu.exe and unpack its contents to a folder. Alternatively, right click on qc848enu.exe and select “Extract to qc848enu\” option.
  4. Insert or plug in the Logitech QuickCam Messenger to a USB port if not already done so.
  5. An “Driver Software Installation” icon in systray (notification area) should appear, which will pop up detailed message if click. It should fail, and “Add Hardware Wizard” dialog window will appear. Choose to install the driver manually by instructing the Wizard to locate and look for the web cam driver inside the Drivers folder under the unpacked folder of the qc848enu.exe setup program. You can use browser button to select the folder.
  6. Windows Vista should grab the XP driver and install it properly.
  7. Download the latest version (10.5.1) of Vista compliant QuickCam software from Logitech to install the software on Vista.
  8. Run the setup (qc1051enu) normally. You may need to skip the detection of webcam near the end of installation process.
Voila, you can now use the Logitech webcam to capture images or use it in conjunction with video chat in IM programs such as Windows Live (MSN) Messenger, AIM Messenger, Yahoo! Messenger, Skype or run Logitech VideoCall.
i hope thist post can solve your problem
thank's
cropp
Mar 14, 2008 | Logitech Webcam
Logitech Quickcam Zoom 5 Pack Webcam Logo
78 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
