Question about Microsoft Excel for PC
Excel software not started
Dear sir,
when i am tried to open excel (office 2000) suddenly it is not get opened. Excel exe has generated errors and will be closed by windows. you will need to restart the programs. an error log been created. can not find the path.
the above message has coming hence kindly help on this issue
    Novelist:
  • 233 Answers
MS Office repair:
Go to the "Add and Remove Programs" in your Control panel. Click the "Change" and do the 'repair program' utility.
That should fix it, good as new.
Be sure to have your INSTALL disk handy (for all Microsoft products).
Posted on Oct 25, 2007
Excel workbook error
I came across this issue today. An update to the Office Compatibility Pack that was still on a computer caused the default PROGRAM for .docx and .xlsx files to be the Microsoft Open XML Converter program and make the "Default Programs" in Control Panel think that Excel and Word were actually the Microsoft Open XML Converter scholarship essay writing assistance program as well.UNINSTALLING the Office Compatibility Pack in Programs and Features and then a simple reboot fixed the issue.
Also:
1: Try to repair it manually when MS Excel does not automatically STARTS File recovery mode.
Click the Microsoft Office Button, and then click OPEN.
Now select the corrupted workbook that you want to open.
Click the arrow NEXT to the Open button, and then click Open and Repair.
Choose either Repair (to recover as much of the FILE data) or Extract data (to extract values and formula when repair process is not successful).
2: Open with Open Office: Try to open your Excel file in Open Office. It is an open-source Office suite that is able to open & SAVE Microsoft Excel files.
3: Save in HTML Format: Open your Excel file and save it in HTML format. By saving the workbook in HTML format, you may be able to filter out the corrupted elements.
4: Save in SYLK Format: Open your Excel file and save it in SYLK format. By saving the workbook in SYLK format, you may be able to filter out the corrupted elements.
5: Try 3rd party software like Excel Repair Toolbox
link: https://www.repairtoolbox.com/excelrepair.html
Jun 18, 2015 | Microsoft Office Excel 2007
Recover xlsx file damaged
For xlsx files, they are actually a group of files compressed in Zip file format. Therefore, sometimes, if the corruption is only caused by the Zip file, then you can use Zip repair tools such as WinRAR to repair the file, as follows:
1. Assuming the corrupt Excel file is a.xlsx, then you need to rename it to a.zip
2. Start WinRAR, go to "Tools > Repair Archive" to repair a.zip and generated a fixed file a_fixed.zip.
3. Rename a_fixed.zip back to a_fixed.xlsx
4. Using Excel to open a_fixed.xlsx.
If doesn't help look for the answer here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/excel/653-i-get-a-message-that-the-file-is-damaged-or-corrupted
Or:
XLSX Repair Kit. The latest corrupt XLSX file repair software featuring a powerful data recovery core and a convenient step-by-step wizard for extra convenience.
For more information: http://www.xlsx.repair/
Dec 13, 2014 | Microsoft Office Professional 2007 Full...
How do i get into a spreadsheet when i get a message saying it can't be opened
Hi, what is the exact error code you receive? If you can provide the exact error code or message, will narrow down troubleshoot. To get around the problem, try starting Excel in safe mode. The command is "C:\Program Files\Microsoft Office\Office14\EXCEL.EXE /s".
To run the command:
1. Copy the above command without inverted commas.
2. Click Start and paste by pressing "Ctrl + V" and press the Enter key.
See if this open Excel. Thereafter, exit Excel and try opening Excel again in normal mode without the "/s" switch at the end.
If still having issue, suspect some of the system files may be corrupted. Run Office setup and hit Repair when prompted.
Regards,
Maha
Apr 29, 2014 | Microsoft Excel 2010
How i recover my demages excell files
Close down Excel, re-open it and try to open the file again.
If this doesn't work, restart the computer, open up Excel and try to open the file again.
If this doesn't work, delete the contents of your c:windows emp directory then reboot. Try again
If this doesn't work, open Excel in Safe Mode. This will disable VBA and Add-ins.
  • Click on Start then Run then enter (including the quotes and the /s extension): "C:Program FilesMicrosoft OfficeOfficeexcel.exe" /s ["C:Program FilesMicrosoft OfficeOffice10excel.exe" /s (for Excel 2002, Office XP, click cancel if the MS Office Installer starts, Excel in safe mode will still start)].
  • Try to open the file.
If this doesn't work, be sure to scan the file for viruses. If you don't find a virus, find the file in Explorer, right click on it and rename it, replacing the .xls extension with the .doc extension. Try to open it as Word document.
If this doesn't work, try to determine if the file is unrecoverable on the disk. Open the file in Explorer and try to copy it to another location.
  • If you can copy the file to another location, skip to step 9. If not, the actual sectors on the disk may be corrupted.
  • If the data is valuable enough to you, seek professional services as a damaged hard disk file recovery is not for the faint at heart.
If the recovered file won't open or you could copy the file to another location, try to open the file in a more recent version of Excel. As the version numbers increase, their ability to recover corrupt files increases. If this doesn't work or such a version of Excel is not available, see if some other spreadsheet application is and try to open the file in that program.
If Microsoft can't help you (see the tips section) and you've exhausted all the free methods above for damaged disk recovered or copyable files there are a number of excellent commercial applications which will recover your files almost immediately.
http://www.repairmyexcel.com/
Dec 10, 2010 | Computers & Internet
Sir when I double click on my excel file message coming '' there was a problem sending the command to the program '' I have windows 7
From the Windows Start menu, choose Run and enter
Excel.exe /regserver
This will cause Excel to start up, re-register all of its
registry keys, then quit. Now, try opening your Excel files.
May 06, 2010 | Microsoft Office Excel 2007 Full Version...
I WANT Free MS Office 2000 EXCEL SOFTWARE
I don't think you can get any free MSOffice Excel. you can get a reader, but not anything you can use to create spreadsheets, etc. without purchase.
I would recommend trying OpenOffice.org and using that freeware. Works just as good, and opens most Microsoft office extensions.
Aug 29, 2009 | Microsoft Excel for PC
Windows excel file can't open
From Excel, try clicking on the 'down' arrow in the 'Open' button, then select, "Open and Repair," then select the file.
Nov 27, 2008 | Microsoft Office Access 2003 (077-02871)...
Microsoft excel file dose not open autometically
hi Friends
here is the solution ifi Excel opens without opening any file after double clicking on the excel file,
1. Tools>Options>General uncheck "Ignore other Applications"
2. Exit Excel and try again
If this doesn't work try to re-register Excel
1. Close Excel first and On the Windows Taskbar
2. Start>Run "excel.exe /unregserver"(no quotes)>OK.
3. Start>Run "excel.exe /regserver"(no quotes)>OK.
See the space between exe and /regserver
if there is anyother issue in which may i help u then feel free to contact me
kamal_lalwani@dell.com
kamal0806us@yahoo.com
+9742128873 /
Jan 23, 2008 | Microsoft Excel for PC
Microsoft excel dose not open autometically
go to start then all programs then microsoft office look for excel click on it from there ok see if it works if not reinstall program and update it ok
Jan 23, 2008 | Microsoft Office Professional 2007 Full...
MS Excel
Can you please provide any additional information, including error messages generated by Excel? Without knowing the specific error message, your surest solution is to completely uninstall Microsoft Office by going to your Control Panel and double-clicking "Add/Remove Programs". Then, once Microsoft Office is uninstalled, reinstall it using the CD.
Nov 12, 2007 | Computers & Internet
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
71 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
