Question about RIM BlackBerry Pearl 8100
Palm tx power button
Power button does not work. How to use any other button to turn my TX on.
    Problem Solver:
  • 10 Answers
Under the settings you can have it turn on when you push the Home button for example.
Posted on Nov 10, 2007
I read somewhere that the power button is actually welded to the motherboard in the TX. I rarely use my power button for that reason. I just touch one of the buttons at the bottom and mine comes on and I let it go off automatically in 30 seconds that I have it set for if I don't need it right away.
Posted on Nov 03, 2007
1) try a soft reset
2) If that doesn't work, you must go to www.freewarepalm.com to find a power hard button replacer.
Good luck
Pd: my unit has random power button malfunctions too.
Posted on Oct 26, 2007
Hi! I bought a referbished TX from you in January of 2009 (I think). It has been working great. However, the other day when I turned it on, the digitizer wouldn't work. Buttons work, everything else...
Disclaimer: I'm just a tech answering you request. I don't know who sold you the TX.
Have you tried to reset the TX?
First, save your data:
http://kb.palm.com/wps/portal/kb/common/article/16478_en.html#tx
then reset:
While holding the Power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the RESET button inside the hole on the back of your device.
The RESET button may be somewhere else on the back of your particular device.
First you'll see a palmOne or Palm logo and a progress bar. Keep holding Power.
Then you'll see a grey circular Palm PowereWhen the warning appears, press Up to confirm the hard reset.
If a language selection screen appears, select the same language you selected for your desktop softwared logo. Now you can release Power.
Then sync it to you PC.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 11, 2010 | Palm TX Handheld
Have to reset Palm TX to power on sometimes
I have a palm TX and it usually just sits for a minute or two when I use blazer. I have also found out that the pda will always reset itself and it only freezes when it has a lot going on. It stays frozen for a while, but eventually unfreezes. As for the home button, it's probably worn down. My power button and my up button have almost completely stopped working.
Sep 09, 2009 | Palm TX Handheld
I bought a used Palm TX Handheld can't clear previous owners password.....Can it be reset to change the password?
Yes it can. Hold the power button down and use the stylus to push in the reset button on the back of the TX. Keep holding the power button down till you see the screen powering up. Then let the power button go, you should see a menu asking if you want to reset the unit. select yes (qui). then it will clear all the data and password off.
Then download the latest Palm Desktop Manager and the Hotsync from this site:
http://kb.palm.com/wps/portal/kb/common/article/32859_en.html
Aug 28, 2009 | Palm TX Handheld
Hard rest plam tx
Here are the steps to do a hard reset. Best wishes.
1. Press and hold down the power button.
2. While holding the power button, use the tip of the stylus (or similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm Power logo to appear and then release the power button.
Aug 18, 2009 | Palm TX Handheld
Palm tx wont turn on
When the battery is discharged, it is best to charge it overnite.
Have you reset the TX?
Hold the power button down and push in the reset button on the back of the TX with the stylus. Hold the power button down until you get the screen where it ask you if you want to erase/reset the unit. click yes to reset.
Then when it comes back up, re-sync it with the Palm Desktop on your computer.
Thanks, Joe
Jun 17, 2009 | Palm TX Handheld
Palm TX handheld
First you need to reset the TX:
hold the reset button on the back of the unit, then turn the power on. Hold the power button while releasing the reset button. The TX will power up to the screen where it will ask you if you want to reset it to factory default.
Afterwards go to this link,
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1568,E=0000000000263321976,K=3877,Sxi=4,case=obj(32859)
and download the Palm Desktop/Sync software and install it onto your PC. After installing the the Palm Destop software, connect the sync cable to the PC via the USB, then connect the cable to the TX and push the sync button.
Thanks, Joe
Mar 29, 2009 | Palm TX Handheld
My Palm TX device is not initializing. it says "palm powered" then a loading bar starts at the bottom of the screen, then it turns off...and it repeats the same thing over and over again.
Have you tried a hard reset? In case you need to know how...Hold Power button on Top of Palm down, then press reset button, then release reset button and continue to hold power button down until second Palm logo comes on screen and progress bar at the bottom of screen completes. If you release the power button and it asks which language you want to use you have done this correctly.
Jan 21, 2009 | Palm TX Handheld
Palm Pilot tx will not switch off
Could be a malfunction with the power button.  Go to settings and make sure the sleep timer is set.  That will save your battery life.
Oct 03, 2008 | Palm TX Handheld
Palm TX power button and touchscreen
We have three TX's in our family with non-working power buttons. I downloaded the program Au Dodo http://www.freewarepalm.com/utilities/audodo.shtml and simply now use the far left button (button 1) as my 'power' button. It works wonderfully.
I haven't found out how to fix the calibration problem, but power on/off has been totally fixed. Good luck for you.
Jul 06, 2008 | Palm TX Handheld
The palm powered icon
To do a hard reset, hold down the power button, press the little reset button, release it, then release the power button.
Make sure you back up your TX first.
Jan 29, 2008 | Palm TX Handheld
RIM BlackBerry  Pearl  8100 Logo
732 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
