Question about ASUS P5RD1-VM Motherboard
Kingston valueram 512mb
Uhh i installed it and nothings showing up . I went into the bios , did nothing and just saved to try to make the computer recognize it . Any ideas ? and im running vista ultimate
  • 661 Answers
How do you mean nothing is showing up?
The fact you can get into BIOS usually means that something is right.
This board can go upto 2GB RAM
look at the kingston configurator page for info and compare it against the memory you bought (exact part numbers are a must). With Windows VIsta Ultimate you should be using 1gb Sticks not 512.
Posted on Oct 26, 2007
SOURCE:
Can i use ddr2 kvr800 for my pc
Product Details Kingston DDR2 800 2G Memory Ram 1).Capacity :512MB.1GB.2GB 2).Model:KVR800D2S6/2G 3).Interface :DDR2 SODIMM computer ram,memory ram,laptop ddr ram,memory module Product Description User Rating: 0.0/5 Kingston Technology Kingston ValueRAM Computer RAM 2 GB - of DDR2 SDRAM, KVR800D2S62G KVR-800D2S62G KVR800-D2S62G KVR-800-D2S62G KVR800D-2S62G KVR-800D-2S62G KVR800-D-2S62G KVR-800-D-2S62G KVR800D2-S62G KVR-800D2-S62G KVR800-D2-S62G KVR-800-D2-S62G KVR800D-2-S62G KVR-800D-, ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices. Product SpecificationsModelBrandKingstonModelKVR800D2S6/2GType200-Pin DDR2 SO-DIMM
Apr 03, 2011 | Computers & Internet
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
1GB seen as 512Mb
I think you are right, you have to update your BIOS, or try to change your Kingston to Super Talent or other compatible with your motherboard ram. Good luck!
Sep 12, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
I just tried to install 1 gig of ram on my IBM T30 Laptop, easy right, well now I get nothing on my screen, so what went wrong if it was so easy. Please help. Thx BJ I tried to increase ram to 1024mb on...
It may require either or both of these, since I can't see the laptop, I'll give you both, first and easiest, is go into the bios, and look in the system settings, see if the memory/ram is set to auto it may be set to a specific amount or speed, f 10 your way out and save the settings, hopefully that will fix the problem, if not then unplug and remove the battary, open the base and remove the little cmos battery looks like a coin, wait 5 min and replace, that is where your settings are saved when the machine is unplugged. Restart after putting everything together, then you may have to go and enable your custom settings, but the memory should show the new stick you installed, If not it's possible you have a bad stick, it won't be the first time, good luck
Feb 28, 2009 | IBM ThinkPad T30 2366 Notebook
Ram Upgrade Problem
There is nothing wrong and your install is OK.
The laptop has used some of the RAM as video RAM for the video card that is part of the motherboard.
You should have noticed that with a single 512Mb RAM you would not have the full 512Mb RAM available to you, the video has grabbed 128Mb of RAM.
Jan 01, 2009 | Acer Aspire 3610 Notebook
A7N8X-E Dlx, 3200+, Kingston Valueram, setup problem.....
there are two parameters that control the cpu speed, one is fsb and the other is the frecuency of ram, make sure your cpu supports what you have and i dont remember where exactly are the options in the bios, but i had the same motherboard and i know they are arroun there just make sure to select 200 mhz for your memory if it is 400 mhz ok? and then make sure cpu supports fsb 400 so your fsb must be 400 in the bios... if you change somethings in the bios and after saving changes and rebooting the motherboard does not respond you just have to take the lithium battery off for 5 minutes and disconnect power cables or move the cmos jumper to reset position and you will be back in zero to keep trying, you cannot damage anything by just trying, but never try to give more tension to ram or any part.
Mar 12, 2008 | Kingston Technologies 512MB DataTraveler I...
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Memory Recognition
The BIOS recognizes the same speed chip. Say, "PNY 512mb 333mhz 12ns". If you mix and mismatch, the BIOS won't see it even though your motherboard will take the differant type chips. They should all be the same.
Jul 10, 2007 | MSI MS-6547 Motherboard
ASUS P5RD1-VM Motherboard Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
