Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My picture is dark
What exactly is the middle board ? I was given a Magnavox 60" and was told that the middle board was causing the tv picture to look dark.
  • 137 Answers
There are 3 tubes , at the end of each tube is a bord with a plug on. inside that plug is 2 point's that sparks, you must open that plug and clean points . you will see dark picture ok.
Posted on Jun 29, 2008
HD TV what would cause a dark gray vertical line in the middle
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Televison & Video
I have a 32 inch MAGNAVOX LCD TV that exactly half of the screen has a gray or white film in front of the picture but the picture can still be seen behind it. The other side of the tv screen is perfectly...
This problem is the cause of the T-CON board is dying.This T-CON board sit at bottom of the LCD screen right in the middle of LCD screen.Change this T-CON should solved ur problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 05, 2010 | SNK Magnavox 32MD357B_37 32 in. LCD...
Greenish colors, and sagging screen picture
Ur tv have a problem known as a "CONVERGENCE" problems.The convergence board the 2 STK covergence ICS and some or all it supporting resistors are dead.All these parts must be replaced to get the convergence to conform once again,to produce a solid good picture.The tv shop should charge u for this job,for $300-350 for parts and labors.
May 21, 2010 | Philips Magnavox 51MP392H Rear Projection...
I think my color tubing is out it is sooo dark you can barely see
Not necessarily so, it may not even be the tube but a fuse that costs a few dollars. Get a proper investigation and quote
Aug 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a Philips Magnavox ptv843 and it has a red tint. The picture is really dark, I can hardly see anything in dark seens. I tried to adjust the contrast and brightness but no help. Thanks
These TV's are known for polluted coolant in the picture tubes.The coolant is between the lense and the tube. The factory has a Service Bulletin about this problem and they say to change the coolant in each picture tube. This will make the TV look like it did when it was new.
Aug 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
60" magnavox tv
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
May 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
no this is what you need...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Wavy lines
I have the same problem with this tv. i took it to a tv repairman, and he told me my convergence circuit board was the problem. the circuit board itself is about $300 and the labor to fix it is another $150. So i never got it fixed, cause it's just too expensive.
Jan 03, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
149 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
