Question about Sony KP-57WS500 57" Rear Projection Television
BLUE SCREN MY TV WENT TOTALLY BLUE . I OPENED THE BACK AND ONLY THE BLUE PROJECTOR WAS ON . WHEN I TURN THE POWER ON AND OFF ALL THREE WORK. I UNPLUGGED THE CONNECTOR ON THE BLUE PROJECTORS LOWER BOARD THAT JUMPS TO ALL THREE PROJECTORS ,AND CONNECTED IT TO THE GREENE PROJECTORS BOARD WHERE THE JUMPER FROM THE BLUE ONE GOES. NOW THE OTHER TWO (RED AND GREEN) WORK FINE---WITHOUT THE BLUE . I GUESS MY PROBLEM LIES IN THE BLUE PROJECTOR. MY QUESTION IS DO I HAVE TO REPLACE THE WHOLE ASSEMBLY OR IS THEIR SOMPTHING ELSE I CAN DO TO AVOID BUYING THE WHOLE ANCHOLLADA.IF I DO HAVE TO BUY THE WHOLE THING , WHERE DO I GET IT FROM. ANY ADVICE WOULD REALLY BE Apreciated
  • robdel Oct 26, 2007
    thank you for your time . tried what you said but there was no change. thanks again
Check you soft ware it looks like that you gone a service mode then you change save, reset your tuning try again tuning all channells the save the data the turn it on again.
Posted on Oct 25, 2007
Audio but No Picture!
Unless you are absolutlyey sure that the value is correct on the resistor replacement I would put the original back in if it still checks good. I could not get you a Service Manual, but I do have a nice trouble shooting guide that I can send you. I just need your e mail.
Apr 16, 2012 | Toshiba 61HX70 61" Rear Projection...
Screen on Dell Inspiron 2200 went totally dark 2 months after warranty expired. Computer still works when I use cables and hook it to TV - but that is very inconvenient. Help?
that means the scren totally went down, there no way to fix, unless you send back to dell.
but there is a evsy way to use the bottom part that buy a extra LCD screen, so you can still using your laptop and display on the larger LCD screen
Dec 29, 2009 | Dell Inspiron 2200 PC Notebook
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
I stored my TV for 2 years and when I went to turn it on the green power light came on for 10 seconds then turned back off. That's all the TV does now. The screen is blank and the TV does not come on.
Try this:
1- Unplug power for 10 minutes.
2- Plug in and turn on again.
if it doesn't turn on then The power supply is bad. Usually the power supply unit can be replaced, but you have to open the case to see how it looks like before order the same one.
Jul 03, 2009 | Mitsubishi HD1000U DLP Projector
No video on our tv
I found in the manual on page 13 bottom, that if you PRESS STOP buttom for 5 seconds of your remote controller then you can see the picture on the interlaced mode again on your TV.
Otherwise you have to connect you DVD to a unit that has progresiv scan, such as an HDTV, some computers if they have an input or to a projector .
I connected my DVD to a projector thru the VIDEO output and put eveything back to normal, and it is working fine now.
System Reset
Open CD disk tray. Press stop key and hold for 15 seconds, screen will appear.
Apr 01, 2009 | Akai DVPS760 DVD Player
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Blue scren
on your tv there are three electrodes on ctr R-G-B JUST ONE BLUE
IS ON SATURATION , NORMALLY THE CIRCUIT DRIVE FOR EVER
COLOUR IF FUNCTIONING GIVES A TENSION CORRECT , SURELY THE DRIVE BLUE IS MALFUNING
Nov 21, 2007 | Sanyo DS32920 32" TV
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Red bow at top left and botton left of screen
Lost of high voltage on the vertical amp was caused the bowing. That was a simple tweak. I'm sorry to tell you that the high voltage adjustments are rather precise and have major interaction with each other. The HV circuit is also used to power low voltage circuits to gain efficiency. If one or more are not within spec, the process to recovery will require bench alignment of the various stages. Seek professional help or consider replacing. Good luck
May 21, 2007 | Philips 60PW9363 60" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
