Question about Maytag MDB9100A Dishwasher
Racks corroding. The dishwasher works great. Just had recall repair done. Problem is the racks are slowly corroding away and new ones cost as much as a new dishwasher. How do I find good used racks and what model racks are interchangeable? The actual model number is mdb9100aww, but it won/t let me enter the ww. Ted
  • 18 Answers
Re: Racks corroding.
Check on Ebay. I just entered this to check for you. maytag dishwasher racks" and there were several on there. One was universal and could be used with 40 different model numbers.
Posted on Nov 18, 2007
0 characters
3 Points
Where can I buy replacement dishwasher racks for an ancient machine?
The racks are probably no longer available new but if you check with appliance repair shops they shouls have something that will work because several brands are made by the same mfg and parts wioll interchange.
May 12, 2014 | Dishwashers
White film on inside of dishwasher on racks and dishes, plasticq
There will adjustment in the respective compartments for reducing or increasing the detergents. Adjust this. Refer manual. Finally have a look at the inlet water quality for excessive calcium!
Apr 15, 2010 | Bosch SHU5315UC Dishwasher
We would like to get the cost of 2 dishwasher racks for a Meiko DV80.2 dishwasher. I beleive the racks are 20 x 20.
The product costs 9249.95. check this link for reference
May 13, 2009 | Meiko DV 80.2 Dishwasher
Dish racks for Kenmore Ultra Wash Model #665 is a great place to look. But from past experienc, dishwasher racks are very expensive and almost 1/2 the cost of a new one. Good luck.
Apr 21, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher rack rotting
Depends on the age.
Eventually dishwasher racks deteriorate.
It is rusting from the inside out.
Replace the rack.
Mar 12, 2009 | Whirlpool 24 in. DP840D Free-standing...
Racks rusting and falling apart
Do not know about a recal. But you can buy the racks at your local Sears service senter or on line at
Dec 17, 2008 | Kenmore 15529 Built-in Dishwasher
LG DIshwasher
hi Problems with the dish racks usually occur because the racks have been jammed back into the tub housing after they're fully loaded. Careless handling can exert enough force to crack or break the roller wheels or throw the racks off the tracks. The solution is easy: Stop jamming the racks.
The repair is easy, too. Remove the racks by pulling out the tiny metal pins that hold them in the tracks. Or simply lift up on the racks and pull them out of the tracks. Then reinstall the racks on the tracks so that they roll smoothly. If the rollers are cracked or broken, replace them with new ones of the same type. The rollers may be friction-fit to their hubs. Pull them off for replacement. Or, if they are held by tiny spring clips, pull the clips out with pliers, or pry them out with the tip of a screwdriver. If you can't pull the rollers off for replacement, remove and replace the entire rack.
Sep 12, 2008 | LG Dishwashers
Rusted racks
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. You can order on-line from this link.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | GE GSD2200G Built-in Dishwasher
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Maytag MDB9100A Dishwasher Logo
514 people viewed this question
Top Maytag Dishwashers Experts
Michael Thomas
Michael Thomas
Mike Cairns
Mike Cairns
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
