Question about Hitachi 53UDX10B 53" Rear Projection Television
TOO BIG TO GET INTO MY FRONT DOOR
My parents are moving and they have asked me if I want their 53UDX10B. I would love to have it but it will not fit through my door. Can it be taken apart and moved in two peices.
thx
    Genius:
  • 1,694 Answers
Take off rear cardboard back and then take off back cover-
BE CAREFUL--the mirror is inside! Then move into house.
Clean out before reassembly--Dust RGB lens caps with soft
cloth, Knock down any spider webs and clean mirror with glass
cleaner & paper towels.........T.
Posted on Oct 25, 2007
I have an emerson tv in hotel room and someone put parental lock on chanel 29 and I can't unblock it. what do I need to do?
In a hotel you say? I would first call the front desk and ask them for it may be blocked by them and you need to pay for it extra to view it through their system... Hope this takes care of it for you, Jesus loves you, John 3:16-17 (KJV)
Jun 09, 2018 | Emerson Televison & Video
Trying to align 65 coupe doors after painting. Weather stripping not sealing front of both doors. Should i take it to a body shop or do it with help?
Most of the time I adjust the doors all the way to the front, supporting the door with a hang strap or a jack with a protector on it. As you first close the door be carefull as the front fenders can be back a bit anf the door and the fender might hit. Most big builds the doors are fitted with the front fenders off and them after the doors aree fitted. ( putting paper in the weather stip and setting the drag of the paper and them the fenders are fitted to match the doors them the hood is fitted to match the fenders, some times the fenders need adjusted some to fit the hood squarely.)
Jun 21, 2011 | Chevrolet Corvette Cars & Trucks
It will not stay on after you power it up
Replace Both of the STK ICs,they are big black ICs and will be mounted to big Aluiminm Heat Sink
they will have part number on them STK392-110,use 120s or 150s also check all of the resistors
in front of ICs Low ohm resistors RK42 RK46 RK50 RK58.
Mats Electronics has Parts 1-800-628-1118 Ask if they have Convergence repair Kit.
Jan 28, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Hello, I just bought a 1994 Jeep YJ (Sahara). The doors do not fit right. Is this a common problem? How do i fix? the pins seem to be straight, and the hinges have not moved (no sign of damage or...
Hello, if the doors aren't closing right you can loosen the bolt that the doors latch onto, it is a torx, then move it up or down so that it closes well. Otherwise you can bend the door pins slightly. What can happen is that the body shifts with the removal of the hard top or if someone unbolted the roll cage to put down the front wind screen. Get the doors going good by adjusting the bolt that the door jam latches onto to keep the door closed. Then tighten everything good. It is common that they don't close right. Also, while you're at it, pull up the carpet where the seatbelts are in front and look for rust on the floor. YJ's are know for the seat belt ripping out of a rusted floor and the passengers going through the windshield. But I still love jeeps. Cheers bro.
Mar 18, 2010 | 1994 Jeep Wrangler
I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Aug 29, 2009 | Life Fitness T3 Treadmill with Advanced...
Swift front end
hi, their is no reason why it wouldnt fit but it would take alot of work to make it fit you might have to cut pieces out of the golf parts to make them smaller or bigger to fit.
Also you would need to be able to weld plastic parts back together and also alot of metal work making brakets etc it would need alot of filling and sanding.
It would be a big job you would have to move mounting brackets etc but anything is possible with time and money.
You could always get the parts you want and just see what works involved sometimes you can get away with out much work at all but others could mean lots of cutting and re-fitting depends how much time and expertise you have got its not something a novice would take on as it is a big job.
Let me know how you get on or if you need further assistance ok
Aug 25, 2009 | 1994 Suzuki Swift
Parental Control Password
Use the code 7777 to erase the current code.This will set the code back to the factory default code which is 0000.
Apr 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53udx10b
Good Day, bostonsuxs;
Like every else in the world you have a convergence problem.
It is not an easy repair so I would suggest that you call an Authorized Service Center and have them give a written estimate, first. If you want to repair your self get KIT 10 from B&D ENTERPRISES AT 1-800-458-6053 or www. bdent.com.
Good Luck, big IRISH.... PS try texas.
Jun 19, 2008 | Hitachi 53UDX10B 53" Rear Projection...
53UDX10B
Good Day, peterferd;
Try resetting the TV by unplugging from A/C outlet wait 3 to 5 minutes then plug back in. No fix? Call service company.
Apr 16, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
130 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
