Question about HP vs15 15"LCD Flat Panel Monitor
I CANT GET THE SOUND TO WORK THROUGH MY MONITOR
MY HP MONITOR IS NOT LETTING ANY SOUND GO THREW. IT HAS WORKED BEFORE AND JUST SUDDENLY QUIT! ITS A 15 INCH F1705/F1905  IF IT HELPS ANY. I CHECKED TO MAKE SURE ALL CONNECTIONS ARE GOOD WHICH THEY ARE BUT STILL NO SOUND I'M NO THAT COMUPTER SAVY SO I DONT KNOW WHAT TO LOOK FOR. PLEASE HELP ,THANK YOU
  • 156 Answers
U get a sound jack attached to VGA cable.Put that jack in the CPU sound output port colored Green.It will solve ur problem definitely.If not, try changing sound level or properties in Windows TASK BAR
Regards
Sandeep
Posted on Oct 25, 2007
Screensaver will not turn on after inactivity
This is an adjustment made in the control panel under I believe Display. From there you will have an option for Screen Saver. It should all be in there.
Jan 01, 2013 | HP w1907 LCD Monitor
How to change my display setting when my monitor sudden stops working at 1076x768 high resolution
uhh it obiously cant take that resolution maby it can try install a new driver if that does work sorry it can take that high of a resolution
Jan 12, 2011 | LG Studioworks 552V 15" CRT Monitor
My HP w22 Monitor started to make a crackling sound and than all the sudden turned off, or something. It wont come back on. The computer works just not the monitor. Any ideas on how to fix the problem?
Try checking your Cable connections to the Monitor to the Computer and from the Monitor to the wall outlet.The crackling sound maybe normal.Most Monitors make that sound.
Jul 31, 2010 | HP W22 LCD Monitor
How do you fix deep scratches in hp flat screen monitor
you cant you will have to buy a new screen or buy some gel for it that might work
please rate my help to you.
thank you
Apr 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Hp slimline pavillion 1503 LCD 15"
plug the speaker cord into the LIME GREEN port on your computer.
Click on the speaker icon at thee bottom of the display to make sure you are not MUTED.
Dec 19, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Display problem in my LG 15'' monitors
1. cheak the filament path diode,capacitor.
2. there is dry points in power section.
3. replaced 3842 IC supply capacitor 47/100v.
4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
Nov 22, 2008 | LG Studioworks 563N 15" CRT Monitor
FP5315 Speakers
Please right click on My computer->properties- hardware-device manager-- check if your sound device is working fine. PLease let us know if we continue further
Sep 24, 2008 | HP Compaq FP5315 15" LCD Monitor
Sound worked and now it dont
The sound for this monitor is connected with the usb cable that is attached to the monitor cable. Replace the usb cable from the pc to the monitor.
Jul 24, 2008 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Hpf1503 switches
Hello Patrick!
If you are technically able you can open the monitor and remove the key pcb( switch off remove power cable).Use a switch cleaning solution like wd40 to clean each switch (spray and operate a no. of times).This might solve your problem.Regarding where you can get it,Sorry I am in India and don't know where you might get it in your part of the world.
Please rate this solution and post your feedback.
Samir
May 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Usb 2.0
Please clarify the term "hard drive usb cable"  Ipods have a special connection on the bottom for sync and charge, and it may not fit another mp3 player.
srich
Nov 17, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
HP vs15 15"LCD Flat Panel Monitor Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
