2007 Honda Accord Sedan Logo
Posted on Jun 05, 2009
Can not locate the CD carousel to load CDs in 2007 Honda Accord LX, 4 cylinder. Handbook shows stereo system with 6 CD changer. There in no ''load'' button. Is this a single CD player?
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Oct 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
7360
Points
42
Its internal the the dash unit press load and stick another disk in and so on
2answers
Location of fuel filter
on the frame on the drivers side
2007 ford taurus air bag light on after replacing stereo
The CD changer option is similar to the single-disc player. The CD changer has the ability to toggle between the stereo and the multi-disc changer. In the 2007 Ford Taurus, the CD changer is located either in the vehicle's trunk or in the center console and has a magazine that can hold up to six CDs.---------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
My Honda accord Sedan car CD Player cannot eject CD .
Before connecting any cables you must set the dip switch box to the position listed for your vehicle. If you set the dip-switches after you have connected cables to the box, you must disconnect and reconnect them for the changer to operate. All 1992-2004 Honda's are compatible with the Neo Changer except the 2003 and 2004 Honda Accord and all Honda Element vehicles. Some radio models require pressing "Seek >" once to start playing after changing CD or after startup. The radios display will not show the proper disc number after disc six. You can use all 10 discs in the magazine, but the readout will be wrong. This is not a technical problem; the car stereo was designed for no more than six discs. *Due to the direct access disc system, you will not be able to directly access discs 7-10. To access these discs you will have to go to the last track on disc 6 and let it play until it loads disc #7. ( you can fast forward the track, but you must let it play the last 5 seconds of the track, for it to change to disc # 7 Switch to the Neo Changer by pressing the "CD" button. To change discs press "Disc -" and "Disc +" To change tracks simply press "Seek <" or "Seek >" S E T T I N G S F O R H O N D A 1 2 3 4 5 6 7 8 ON OFF OFF ON OFF OFF ON OFF
How do i unjam my cd player in my honda accord 2002
I have a 2002 Honda (4 door) Civic LX with a build in 6 CD changer. When I turn the ingnition on the light indicadors above each CD # travel back and forth several times. When I press to play, change or eject, it shows ERROR. What can I do?
Hello, How can I load 6 cds into the audio system of my 2007 honda accord? I do not have the owners manual, kindly assist. Thanks.
Look on the face of the radio for the Load button. Turn on the ignition and then change it to CD by pressing the CD button. Stick a CD in the slot and then press Load. Wait for the CD to load. Now stick another CD in the slot and press Load. keep doing this until all 6 are loaded.
14helpful
Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
8helpful
2answers
6-disc Cd changer Mechanical Error
I talked to a dealer, all they could tell me is they have to send it to honda to fix it... a good 250$ for software fix...plus dealer will charge 50$ for each time they take the player out and in...
1helpful
3answers
6 CD Changer won't work
I don't have a solution, but the same thing happened to my car. I have a 2007 Honda Accord with a 6 disc cd player and it is reading "Mechanical Error" and it won't work and all my cds are stuck in there.
CD player (6 disc changer) "locked up"
Take it to the dealership, your G35 should have a 4 year bumper to bumper on it. They'll replace the radio under warranty most likely.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
