Question about Samsung Yepp YP-T9 Digital Media Player
USB connection cycles on/off
Yesterday plug it in to resynch some new playlists and it won't stay connected.
Symptoms USB Connected shows
1 second later USB Not Connected shows
appears to reboot 5-8 seconds and repeats
(just copy pasting another person's post since i have the exact same problem....)
    Problem Solver:
  • 6 Answers
Re: USB connection cycles on/off
I was able to resolve this exact problem by performing a low level format of the device and reinstalling the firmware.
Please note that this procedure completely erases the contents of the device.
1) Visit the Samsung support site specific to your region, obtain a recent version of the firmware and save it somewhere accessible.
2) Turn the unit off, then hold down the record button ( top-most button on the right hand side ) while pressing the power button. If you are stuck in the USB-reset-cycle as I was, holding the record button down while it thrashed about was sufficient as well.
3) Momentarily you will be on the "Low Level Format USB Mode" screen, a prompt will ask for keycodes. At this point your are about to remove all data and firmware from the device, pressing rec+menu will exit this screen leaving everything intact. Otherwise tap in: LEFT,LEFT,RIGHT,RIGHT,TOP,MIDDLE BUTTON, BOTTOM. An asterisk will appear for each key entered, the device will then completely erase the flash memory.
4) Essentially you now have a USB flash drive, powering the device on will present a "USB Mode..." prompt, connect the cable and plug it into an available USB port on the computer.
5) The device will mount as a standard removable device called "YP-T9". Open the firmware zip file downloaded in step 1 and drag the two files to the device.
6) When copying is complete, safely eject the USB device from the system. Power the unit off ( might be necessary to hold down REC+MENU to force it off ).
7) Hold the power button to start the device back up and a "Upgrading Firmware..." message should appear for a few seconds, after which you'll be back at the familiar interface. You may need to customize menu language to the locale of your choice.
You can now sync the device to your collection and enjoy until the next time it happens.
Hope this helps!
Posted on Nov 15, 2007
  • 156 Answers
Restart u r pc.Unplug ur usb cable and replug it forcefully after restart.It is a problem of loose connection.I also meet this problem several times on my computer but resolved in the same way.
Posted on Oct 25, 2007
0 characters
3 Points
Ipod classic 7th generation won't sync
Step 1:
With iTunes software, iPod users can manage their media libraries, purchase or import new content and synchronize their devices. The software has a number of convenient features, one of which is AutoSync. This feature will cause your iPod to automatically synchronize with iTunes immediately upon connecting the device to your computer. You can also set up iTunes so that you can manually sync your iPod.
Press the "Shift" and "Ctrl" keys on your computer keyboard simultaneously while you connect your iPod to the computer using its USB cord. Mac users will press "CMD + Option" while you connect. Continue to keep the keys pressed down while you monitor the iTunes window. Keep the keys pressed until you notice that Auto-Sync has stopped and your iPod icon has appeared in the Source pane of iTunes. Be patient, as this could take between 5 and 30 seconds. Right-click on the icon for your iPod in the Source pane, and then select "iPod Options." Click to put a check mark in the "Manually manage songs and playlists" check box. This finishes your task and you can now manually synchronize your iPod whenever you wish by simply clicking on the "Sync" button.
Feb 10, 2013 | Apple iPod classic 7th Generation
I have lost my playlist file
try connecting the mp3 player to your computer, then after it has connected click on the safely remove hardware or USB icon, disconnect the player and see if it creates a new playlist (mine always updates playlist after disconnect)
Mar 08, 2010 | Samsung YP-U3 MP3 Player
When I plug in my Zune to my PC, my PC doesn't recognize it. I can't manage my music, etc. However, it does charge it when plugged in. Please help.
I am having similar symptoms on mine. Just began happening yesterday. When it's plugged into the USB port on my PC, Zune software thinks it's not connected. The Zune itself just keeps booting up repeatedly, but never stays on. When I put in on a charger, it works fine as long as it's on the charger. The moment I remove it from the charger, it shuts down. I've tried resetting it, to no avail.
Feb 20, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
When i connect the device to my computer and make a playlist to sync the playlist it not doing nothing as if the device is not connected its got little zzzs as if its sleeping or not connecting
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds OR Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. **Drag and Drop** Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder; available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player. --**Windows Media Player**-- If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Sep 27, 2009 | Nextar MA933A MP3 Player
How to download songs
1. Are you using Windows Media Player 11 ?
2. Can you see the Sansa e250 connected in the sync mode ?
If no: install and update WMP11
If yes:
3. Make "new playlist" in the <Library> or <Sync> mode
of WMP 11; screen left side.
3.1 Save "new playlist" in WMP11; screen right side.
4. Put in <Sync> mode your playlist under the player: The player
should be connected showing in WMP11. Start synchronizing.
Leave the player connected until <Sync> is ready.
Support for Sansa e250:
Aug 29, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 won't stay connected to the computer
In this case try connecting the Mp3 Player to a diffrent Slot..........
If still it does the same thing...........
Use a Brand New USB Cable that will fix the Problem,,,,,,,,,,
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
Not all tools active in XIVA Producer Tools Program
so, first of all, i hope you read this after a long time ;)
Xiva Producer sucks and doesn't run under windows. Try some playing with the built in vista compatability mode.
You simply can't sync with iTunes. What i'm currently doing, is connecting the xiva to itunes by simply set the itunes map to the network share. Have in mind that you can't add files in the musicshare map. So disable the auto organize future of itunes.
Jan 03, 2009 | Elan VIA!dj-S MP3 Player
Usb connection
If the solution is really serious, you will probably have to stick it on with tape or something. Or if youre willing to take a risk, you could modify the usb will a pair of pliers.
Jul 27, 2008 | Samsung YP-U3 MP3 Player
Two ipod products on one pc
Hello there! There are a few different ways you might solve this problem. The easiest thing to do would be for you and your husband to each create your own playlists. Consider putting your initials in front of the name of each of your playlists, and your husbands initials in front of his, so that in an alphabetical list, you wind up with all of yours grouped together, and he has all of his grouped together. Now it's time to connect each iPod in turn. When you connect yours, click the iPod icon in the left hand column (the 'sources' column), and click through the tabs to the right until you get to the screen where you can choose to sync 'all playlists' or 'selected playlists'. Click on 'selected playlists' and then check off all of yours (or whichever you'd like at the time, if you have more music than will fit), none of his. When your iPod is done loading up that music, go ahead & disconnect it. Now repeat the process for your husband's iPod, selecting his playlists but not yours. From that point forward, when you plug in each iPod to sync with your library of music, it will remember which playlists it is supposed to sync with, and which it should ignore. Just remember that if & when you create brand new playlists in the future, you'll need to go back into the iPod settings to tell iTunes to sync that new playlist with your iPod (this can be done only while your iPod is connected). Hope this gets you where you were looking to go... best of luck!
Sep 28, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Connected, but no recognition from PC
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 13, 2007 | SanDisk Sansa e260 MP3 Player
Samsung Yepp YP-T9 Digital Media Player Logo
449 people viewed this question
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
