No trunk key
SOURCE: Is there a way to get in my car through the trunk.
ok. if you have auto door locks then this will work. if not,and you work at a fast food restaurant or know someone who does, a fryer poker works 100 times better than a hangar and unlock even a manual lock. you'll need two screwdrivers(s.d.), one thin one thick, and a wire hangar (or that fryer poker i told you about). step 1: straighten hangar. then use one of the s.d. to bend a small one inch hook at one end. step 2: take the thin s.d.and pry the seal away from the top of the window(preferably at the curve-least resistance there). SLOWLY work the s.d. behind the window until it begins to come completely free of the seal. now insert the thick s.d. into the same area. your hole should have gotten bigger. step3: work the s.d.'s apart about 6 inches. pull back slowly but firmly with the thick s.d. and insert the hangar. use the hook to engage the lock switch.
