BenQ DVD±RW Dual Layer Burner
Problem for BenQ (EW162I) DVD±RW Dual Layer Burner
BenQ DVD RW Dual Layer burner (EW1621)tray not opening
By jimboaz on Oct 25, 2007
Tray will not open when button is pushed, had same problem before & it seemed to resolve itself the next time i used it.We manually opened tray by bypassing lock mechanism & inserted cd which came up as drive f busy in windows & also no disc in drive. Throughout attempts at running unit it responded a couple of times in closing mainly but also opening to lesser extent. Also uninstalled & reinstalled, with no luck.
Same Problem
Dec 04, 2008
-   Same as above - it tries to open (I think, as it's making willing noises) but doesn't open. -   Guest
Dec 18, 2007
-   Most new burners and ROMs use two motors. One to speed up the disk. The other for tray transport. The tray transport mechanism uses a belt to transfer power. Unfortunately, a case of a stuck door could mean a blown/worn motor (the usual case), which is hard/impossible to fix on your own, or a belt replacement. Try pressing the button and then messaging the tray door on one side and then the other. You can usually feel it start to pop open. Opening and closing it ofter sort of warms up the motor and for short periods be usable. Problem is, it never feels as peppy as when new, which to me suggests secondary motor problems.-   Guest
Nov 25, 2007
-   Same problem with Benq 1620. Tried fixing registry entry that been corrupted, removed drive and re-installed it, tried to pry it open using manual release hole - no luck with any of this. I suspect that hurling it against a concrete wall may open it.-   bobdog
Nov 24, 2007
-   Same problem as with the LITE-On Combo SOHC-5236V. It wouldn't open, makes the noise. I hit the manual release button under the drive (pin sized, use a paper clip) and then used a knife to pull open the drive. However, after inserting my CD, it fails to read it. Any Suggestions?-   Guest
Nov 23, 2007
-   the same as said, the tray wont open... but wen you push te button it will do as if is trying
-   Guest
Best Solution
posted on Nov 15, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
sony dvd-rw tray is not open help me
Solution #2
posted on Jan 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yeah my friggin Benq dvd dd dw1620 wont open.
Popular Solutions for BenQ DVD±RW Dual Layer
Questions and Unsolved Problems for BenQ DVD±RW Dual Layer
Do you recommend BenQ (EW162I) DVD±RW Dual Layer Burner?
Answer
Answer
hey there, i burned almost 2 gigs of photos to a dvd using the ''send to d: drive'' option and... (More)
Answer
Have a HP Touchsmart with TS-T633a CD/DVD burner. Hardware manager recognizes the drive but calls... (More)
Answer
Just bought a HP DVD556s and will not recognize the media when I try and burn a lightscribe label... (More)
Answer
I can't burn an audio CD in iTunes using my Aluratek burner. is it possible that this product is... (More)
Answer
My dvd tray will not open. I push button and the light blinks and lap top makes slite bleep noise... (More)
6 Other Users Have The Same Problem - Continued
Comment by Bipbip, posted on Nov 19, 2007
Having the same problem with Benq DVD DD DW1620. Nothing I do will open the bay. Tried rebooting but didn't help. Tried troubleshooting menu: no help.
Describe your CD and DVD Burners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
in Sedona, AZ
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
