Question about Hotpoint RGB745 Gas Kitchen Range
Oven takes a long time to preheat
I have a Hotpoint RGB740 converted to LPG. 1 month out of warrenty, the oven has begun to act up. The oven takes more than an hour to preheat to 350. The ignitor is lighting the gas. The flames are a lightly dancing blue with no yellow tips.
The broiler appears to be working.
I have never used the self cleaning feature so I would not know if it was functioning as usual.
The top burners fuction fine even with muliple burners lit.
  • Anonymous Dec 13, 2007
    I have the same problem, My stove is a maytag powerboost,
    Any help is appreciated. Tom
  • 473 Answers
Before we go into diagnosis mode, call the customer service # in the owners manual and complain about the problem.  They usually will make a concession when it is this close to the warranty period.  Let me know what you find out.
Posted on Oct 25, 2007
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Jun 21, 2012 | GE Kitchen Ranges
My oven is only 8 years old. Hotpoint Gas Oven. After preheated, the oven doesn't stay lit.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Apr 23, 2011 | Hotpoint Ovens
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Jan 10, 2011 | Vulcan G36L Gas Range
Hotpoint oven
From MNTECH, "If your oven would light sometimes, but usually not, or take a very long time to ignite, then replace the oven igniter. Even though it probably is glowing, it needs to draw a specific minimum electrical current (in amps) for the gas safety valve to open and release the gas. Also low voltage can affect how many amps the igniter draws, so that may be a factor, but not as often."
I live in Japan. I got a brand new range in june and it has had this problem for four month. The igniter glows but the gas never (or rarely) releases. Often it would preheat but not maintain the temp while baking. **augh** After reading MNTECH's solution I got a transformer and plugged my range into it to change the voltage (100 to 110) and I haven't had a problem since. THANK YOU MNTECH FOR POSTING THIS SOLUTION
Aug 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven overheating
Yes this is repairable, the probe in oven called a thermostat,that wire that goes out the back small hole goes up to the oven temp. knob ie thermostat. part # .WB20K10004 you can find it at about $60.00 good luck
Mar 28, 2008 | Kitchen Ranges
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
771 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
