Question about Acer Aspire 3000 Notebook
Low resolution of my laptop
I was doig the clean up on my laptop and suddenly my screen went different from what it use to be. On the bottom line, it says that my computer is running low on screen resolution. What to do
  • 156 Answers
Right click on Desktop and click on properties.After that click on settings tab.When u see on left down corner of that small window u get a screen resolution box.in this box u have a courser to move left-right.Move it to 1024 by 768 pixels.And u r problem resolved.Don't forget to rate me.
Regards,
Sandeep
Posted on Oct 25, 2007
Laptop LCD monitor (needs advance help) I have a Dell m5010 laptop that started to display small vertical lines from that bottom left corner going up to the top right corner. I plugged the laptop up to...
Try a different resolution in the monitor to see if that helps. You can do this by right clicking on the desktop and changing the resolution within the screen properties. If that does not make a difference, try searching for updated display drivers either through the laptop manufacturers website or its possible you have a bad controller board for the LCD screen.
Nov 25, 2014 | Computers & Internet
Spider Solitaire
What happens when you change the display resolution setting? Maybe the program was written for a different resolution, so the pixels are the wrong size. That may account for the misbehavior, and very likely the menu issue. To change display resolution, open System Preferences... from the Apple menu, then click on Displays. Try a higher resolution (bigger numbers, e. g, 1280 x 854)) first if that is available. This may scale the menu and play area to their intended sizes.
Jun 05, 2013 | Computers & Internet
I was using my laptop (Dell Inspiron 8600)when all of a sudden it froze in a destorted, bad resolution. I hit esc then a white screen came up with different colored lines on it. I turned it off and...
It sounds like either the screen or the signal cable connecting it to the motherboard is defective. The screen is going to need to be replaced.
Hope this helps.
Mar 07, 2011 | Dell Inspiron 8600 Notebook
The picture is too big for the screen. the top and bottom is cute off.
You may need to change your resolution. Here are the steps:
  • Windows XP Right Click Desktop and select properties, then click the Settings tab.
  • Windows Vista Right Click Desktop and select Personalize, then on the bottom select Display Settings.
  • Windows 7 right click desktop and select Screen Resolution
Try some different resolutions until your desktop fits in your screen. You could also try moving your screen around with the options built onto your monitor.
Feb 25, 2010 | Toshiba Satellite A135-S2386 Notebook
My laptop screen went from horizontal to vertical, everything is sideways
Check your display settings. In Vista (I suspect) and Win7, right click on a spot on the desktop with no icons or programs. Select Screen Resolution. There is a drop down menu item labeled Orientation. Change this to Landscape if it is in Portrait or vice versa. (The Screen Resolution can also be accessed through the Control Panel.)
If you have a different operating system, the names may be different but it should be fairly similar.
I hope this helps.
Feb 19, 2010 | Compaq Presario M2000 Notebook
How do you make the desktop full screen on a dell inspiron
Right click your mouse anywhere on your screen/desktop and select "Properties", when the properties window comes up selct "settings" tab and select the different resolution form the window on bottom left. Experiment with different resolution until you see the one you like.
Jan 18, 2010 | Dell Inspiron B130 Notebook
My IBM Thinkpad A21m was working fine, then all of a sudden, the display screen size is about half of normal. When I plug a desktop monitor into it, the screen is full size. What's going on?
right click on an area of BLANK desktop and select properties
Now go to the SETTINGS tab and check the resolution and adjust it to a little higher. click APPLY then OK
If all went well you should notice a difference If not report back to this post and w will see what else needs to be done
If it did make a difference then adjust it more if you need.
Aug 20, 2009 | IBM ThinkPad A21m 2628 Notebook
Screen resolution change = black border around small screen
RIGTH CLICK THEN DISCKTOP THEN PROPERTIES,DESPLAY AD SETTING, CHANGE INTO 1024 BY 768 PEXILS.... TO FIT THE SCREEN RESOLUTION 32BIT ONLY
Jun 04, 2009 | Dell Inspiron 8200 Notebook
Philips x57 laptop. screen has suddenly went fuzzy. distorted colour and images jumpy.
Have you set the right screen resolution. Check screen resolution & color quality setting in display properties.
Aug 17, 2008 | Computers & Internet
Screen suddenly blank on FujitsuSiemens AmiloProFB21
I am thinking that the Video Resolution went off, so you have to try entering Safe Mode by pressing F8 until you get a menu in black and white...
Then, select Safe Mode. That would reset your video resolution.
Then, reboot the system and let it boot normal. See if it is fixed.
Jul 20, 2008 | Fujitsu AMILO Pro V1000 Notebook
Acer Aspire 3000 Notebook Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
