Question about Samsung 931BF 17" LCD Monitor
On-Screen Menu The on-screen menu of my Samsung 931BF sporadically comes on, and the AUTO configuration runs multiple times at random intervals.
  • pyree Mar 20, 2008
    One site suggested to basically power down for 5 minutes and then restart. that didn't work.
    I tried to install the software that came with it- no help, then uninstall, no help.
    I tried to tape down the menu button, that helped until the button pushed the tape loose.
No solution yet. My 17 inch flat screen monitor clearly says
Samsung Model 731 on the label on the back and yet this model is not recognized by this site. I need help getting rid of this pesky box that keeps popping up in the middle. Other models obviously have experienced the same.
Posted on Jul 01, 2008
    Problem Solver:
  • 19 Answers
You have to check keyboard and the cable which interconnect main board and keyboard it could be damaged.
Posted on Jan 17, 2008
How do i get auto configuration off my screen
Try uncheck Auto configuration when you right click on desktop and choose screen resolution menu.
Nov 25, 2015 | Gateway FPD1530 15" Flat Panel LCD Monitor
Make computer display fit tv screen mitsubishi wd 65738
If you are only going to use the set with the laptop here is a link to the service manual with electrical adjustments for height, width and other things---"enter at your own risk.'
http://www.scribd.com/doc/52160908/27/Service-Menu
Dec 15, 2012 | Mitsubishi WD-65738 DLP TV
How to open case/shell of Samsung SynMaster 931BF???
You remove all the screws, stand, then useing the thin flat blade screw driver to crack open the case, starting at the bottom edge and work your way around, it is hard to tell you in words. Try Youtube also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 15, 2010 | Samsung SyncMaster 931BF LCD Monitor
I have a Samsung SyncMaster 931BF. I love the screen, but for quite awhile, the screen has been having a hard time coming on and staying on. I'll have to cycle the power multiple times to get the screen...
Remove its stand
Unscrew all the screws in the back.
It doesnt just lift off I guess you could say, there are many clamps around the edge that need to be "popped" by sliding anything thin enough to get between the front and back of the case to pop them.
I popped mine open the other night. The clamps appear to be hard to break, at least in my circumstance. None of them broke with a fair amount of pressure from pulling being applied.
Also, mine had your exact same issue until one day it no longer turned on completely. It just flashed the screen once and showed a flashing power light around the button. Replacing 3 capacitors that were just barely bulging on the top fixed the issue.
My auto configuration menu on the monitor keeps popping up and cannot get it to stop what can I do?
auto configuration menu stays on monitor screen constantly while trying to use pc for normaluse.
May 20, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
My auto synch screen flashes on and off periodically and the birghtness menu comes on the screen for no reason and wont go away. How do I fix this?
More likely to have power supply problem when it does strange things.
Very common problem with all LCD monitors. Look for caps with leaking/bulging tops.
See failed SAMSUNG and other brands here to get some idea what to look for inside if you are going to DIY repair.
May 11, 2010 | Samsung 931BF 17" LCD Monitor
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
My psp has no image but it has sound
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
or'
If the LCD screen suddenly turns dark
  • Check the Backlight Auto-Off setting
    If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on.
    To check the Backlight Auto-Off setting:
    1. From the XMB™ menu, go to icn_settings.gif (Settings) > [Power Settings] and press the icn_btnx_color.gif button.
    2. Highlight [Backlight Auto-Off] and press the icn_btnx_color.gif button.
    3. Select a time interval and press the icn_btnx_color.gif button to save. Select OFF if you wish to disable this feature.
  • Check the Auto Sleep setting
    If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on.
    To check the Auto Sleep setting:
    2. Highlight [Auto Sleep] and press the icn_btnx_color.gif button.
  • Check the Display Button
    Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen.
    The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
Aug 15, 2008 | Video Game Consoles & Games
Help setting alarms
To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Samsung 931BF 17" LCD Monitor Logo
228 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
