Question about Hotpoint RB757 Electric Kitchen Range
How do I light my oven?
HI. Who would I call to fix my oven? When I turn it on the light is dim and the room then fills with gas. Thanks.
Amy
    President:
  • 1,314 Answers
Which light is dim amy and dont turn it on till we fix it hold my rating as i need to ask you somes questions before we can repair it but basicly the gas valve should not open with out the oven lighting
Posted on Jan 11, 2008
Self light oven not lighting - gas fills the room
its the hot surface igntior that glows could be cracked might need replacing
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
No heat from my oven Gaggenau EB 868_6
hi amy,
          it seems there is a defect in ur owen..because if light and fan works, it should heat, otherwise it means there is a fault in the heating element..so kindly cal any near by technician to sort out this problem or use our find oven repairman service to contact d near by repairman...
good luck
Jul 06, 2008 | Ovens
Gas oven will not ignite
It sounds like somebody bypassed the flame sensor on the oven, no oven should ever release gas for more than a couple seconds if there is no ignition. This oven is very dangerous and should not be used until it is looked at by a professional.
Dec 19, 2008 | Ovens
DCS wall oven very dim display for settings
typical for gas filled displays. check other postings for same problem for correction. part cost is $92.
Nov 19, 2008 | DCS (WOTD-227) Double Oven
Display light
Found out that I could replace the C3 capacitor with a 100uF 35V (high temperature - 105 C). Spent $1.69 for the capacitor and 1/2 hour taking the unit out, soldering the new capacitor in, and remounting the upper clock unit back on the oven. Works like a charm. No need to buy the whole Clock/Temp unit, waste of money.
Aug 13, 2008 | Jenn-Air W30400P Stainless Steel Electric...
F30 Erorr on stove...
The fault code shows that your temperature probe opened.
1. Check resistance at room temperature & compare to RTD Sensor resistance chart.
If resistance does not match the RTD chart replace RTD Sensor Probe.
Check Sensor wiring harness between EOC & Sensor Probe connector.
2. Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jun 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Magic Chef Oven won't light
Your oven bake ignitor is becoming defective. Even though it is glowing, the resistance is not great enough to "pop" the gas valve open and is slowly seeping gas into the oven cavity. With a strong ignitor, the oven should light within 30-45 seconds. Because this is a gas oven, I DO NOT RECOMMEND FIXING IT YOURSELF. Call an experienced technician.
Sep 27, 2007 | Ovens
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Hotpoint RB757 Electric Kitchen Range Logo
74 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
