Question about Sony STR-DG510 Receiver
No sound coming from subwoofer
I have the sony str-dg510 receiver and tried to hook up a passive subwoofer from my old sony dream system. The connection on the receiver is an rca, and the one on the subwoofer is the two lead terminal. The subwoofer works on my old sony dream system but doesn't make a sound when hooked up to the receiver. Not sure if I need to get another subwoofer. Hoping i won't need to get one. Thank you in advance
  • 9 more comments
  • wownoexpert Dec 04, 2007
    I am trying to use a 3ohm subwoofer from an RCA home theater that I did have. I did find and RCA male to two-wire terminal end cable from Radio Shack so I now have the the proper cable (RCA connector at receiver and two-wire strand end at speaker) to the subwoofer. I have started completely over with setup of the STR-DG510 receiver but I do not get any sound from subwoofer. No sound comes thru when "auto calibrating" nor when running the "test tone" procedure. I have connected this subwoofer to another speaker cable pair and it does work. Any solutions?
  • gooootham Dec 06, 2007
    Have the extraly the same problem with 8ohms subwoofer
  • gp41366 Dec 25, 2007
    I have the same issue. I'm using a bose subwoofer I bought last year. It has 2-wire lead hookup. I bought the 2-wire>RCA converter.
    I've tried 2 different sub woofers also.
    I don't understand the solution provided by accordianman. I hooked it up directly to the sub woofer output on the receiver.
    More info and the steps to correct it please.
  • plantjs1965 Jan 05, 2008
    sony str-dg510 reciever has rca connection and would like to connect it to old sony subwoofer which has two wires? how do I go about this?
  • Anonymous Jan 06, 2008
    I have the same problem... do I need to pass the sub channel from the receiver through an amp?
  • sb6103 Jan 08, 2008
    my 75ohm antennat wire has two wires and my Sony has only one coaxial type connector (center wire)-the outer round cylinder shape is plastic non-conductive. How can I get 'em together.
  • ediboy Feb 08, 2008
    I cant get sound out of the subwoofer on my STR-DG510. It has an RCA output and my pasive subwoofer has plain 2 wires. I tried stipping an RCA cable and conecting it to the speaker but I cant get any sound.
  • jotarz Mar 16, 2008
    I couldn't hear any sound or detection during the test tone calibration, is this normal? cause if watch movies I can hear the sub workign except during performing the test tone.
  • wpaddayuman Jul 12, 2008
    i have a sony str-de945 receiver and bose lifestyle 12....how can i hook up the bose subwoofer to the receiver.....ty
  • drako78 Feb 14, 2009
    Does anybody know what kind of speakers do I need for my Sony STR-DG510? My subwoofer from my old sony homeTheater do not work, no sound , nothing. Why will I need an Active subwoofer with this sofisticated multichanel STR-DG510? all this technology and power to make work 4 small speakers???
  • Anonymous Feb 18, 2009
    There is conflicting opinions. Passive or powered. Do you have to buy both and take one back?
  • 397 Answers
Sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Posted on Jan 20, 2008
Your receiver does not have a power amp to drive the speaker in the subwoofer while your other amp did. With this receiver you need to use a powered (active) subwoofer which has it's own power amp in it. You can either change out your subwoofer to a powered (active) subwoofer, or keep using your passive (unpowered) one and add a power amp between it and the receiver. The easiest way to tell a powered subwoofer is to see if has a place to plug it into the wall. If it does, it will most likely work in this situation.
Posted on Feb 19, 2008
I had the same problem. I had an old Powered SubWoofer tried it and not I have sound.
Posted on Jan 07, 2008
  • 979 Answers
The output on your new reciever is not a speaker output...accordianman
Posted on Oct 25, 2007
Can I and how do I hook a subwoofer to my Sony str-de705 receiver
It depends. You can connect an active (self-powered) sub-woofer to the STR-DE705. You can't connect a passive sub-woofer that needs power from the receiver. If the sub-woofer has its own power cord, then it's an active unit. See https://us.en.kb.sony.com/app/answers/detail/a_id/37001 for more information. You'll also need a RCA subwoofer cable. This is like a RCA audio cable but only has one plug on each end. (Using a regular audio cable may risk a short when the extra plugs hit something.) Many subwoofers will come with the audio cable. If you do need one, they are available at most places that sell cables, including Amazon.com .
Here is an example of an active subwoofer: https://us.en.kb.sony.com/app/answers/detail/a_id/37001 . This is the Yamaha YST-SW012.
I hope this helps.
Mar 15, 2016 | Sony Audio Players & Recorders
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
I have the sony str-de1075 reciever.i want to hook up a sub-woofer.but it only has 2 single port.not your reg.rca ports.what do i do..thanks..
Sorry but it's not clear enough what kind of subwoofer (passive or active) you want to use. The passive one has no power supply connection, the active one has a power supply connector and the audio connector can be connected at the "audio out" for the subwoofer, at the rear panel of your STR-DE1075. Take a look at this photo:
In case you need a user manual for your receiver, here is an official link.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jul 22, 2011 | Sony STR-DE1075 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Do the HDMI ports support audio or do I need to go buy optical cables to use them on my STR-DG510
The STR-DG510 carries video only over the HDMI port. Technically, this is a "pass-thru" port. Most older receivers are engineered to operate this way. Why? I don't know. You MUST provide the audio connection using a separate TOSLINK or RCA cable from the program source to the receiver while your video is connected via the HDMI port.
Stick to IT work, MSOFT IT pro. I got smart and bailed out being an IT guru. I got better things to do than screw around with the idiotic nonsense of Microsoft operating systems and applications being a thing of fashion rather than being useful and practical.
Aug 01, 2009 | Sony STR-DG510 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
Sony STR-DG510
I think you have to run a separate audio line from the dvd to the 510, because the HDMI is only passive
Mar 12, 2008 | Sony STR-DG510 Receiver
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Sony STR-DG510 Receiver Logo
3,320 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
