Question about Kodak EasyShare V1003 Digital Camera
Camera will not turn on
My camera will not turn on,  I have checked the battery.  I've tried charging it.  There is no lights, showing that it's charging.  It will not do anything.  No, I have not dropped it or damaged it.  I keep it in a case and put up.
  • 8 more comments
  • Anonymous Nov 17, 2007
    My camera will not turn on. Have to take out battery and put it back in... Even then it still doesn't always turn on; as if bad connexion between battery and camera. Battery is fully charged.. Getting worse...
  • broker Nov 20, 2007
    I charged the battery (brand new) less than a week ago, today I took about 3 pictures, the camera went off and would not turn on. Note since the initial charge I've been playing with it fo familiarize myself with this camera, could this be due to low battery. I also notice that at the initial charge no lights went on. Please help.
  • Anonymous Dec 09, 2007
    I tried charging the battery. Sometimes the lights come on, other times they don't. I have the Kodak V1003 and I love it when it works, but its a headache when I have to remove the battery then put it back in just to catch special moments. Good luck if its spur of the moment pictures because its not reliable to turn on sometimes.
  • clarisse18 Feb 14, 2008
    my camera worked 10 mins ago.. and then i tried it now. and it wouldnt actually work. it is the same problem as what you said. is it really just with the battery??? pls help.. i only bought the camera in december
  • jobber72 Mar 27, 2008
    Same thing here. Battery seems dead, camera won't turn on, will not charge, no lights.
  • Font Jun 17, 2008
    When I turn my camera on a black flower like object appears on the view screen. I am not able to see any images on the view screen. I have only used my camera a few times.
  • vthibodeau Jul 30, 2008
    Camera will not turn on. Battery will not charge - there are no lights. In other words, the camera is dead and I cannot use it.
  • Anonymous Aug 02, 2008
    will not charge. sometimes it has a blue light and starts charging then it stops out of the blue
  • mertmert Sep 12, 2008
    my camera will turn on sometimes and wont other times. I have checked the battery, charged it..and still nothing. It always happens when I really want to take a picture
  • prettyladynh Nov 27, 2008
    I have a Kodak Easyshare V1003, I can not get it to power up/ charge, it does nothing! No lights, no sign that it is charging, just nothing! I have not dropped it or damaged it in anyway whatsoever! I am not pleased at all! if anyone has a solution to this problem, please help!
Replace the batteries... This happened to mine and it was the battery.. however it can be the LCD is shot if that does not work...
Posted on Sep 05, 2008
  • 156 Answers
Try replacing the batteries
Posted on Oct 25, 2007
SOURCE:
MY Hc v110 Camcorder is not turning on. I've checked the battery and that's completely fine. HELP
How do you know the battery is actually "fine"? Did you put a meter on it or have you tried another battery? The battery can show to be charged but not working if it's gone bad.
Also, try removing the battery for at least 60 minutes, check and clean the contacts on the battery and in the camera, then install the battery and see if it will start. Sometimes removing the battery for some time will reset the camera.
Dec 29, 2014 | Panasonic Video Cameras
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
My finepix s3400 will not turn on. I've tried almost everything and I'm really annoyed. Is there something i can do to fix it?
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
Mar 08, 2012 | Fuji FinePix 3800 Digital Camera
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Dec 27, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Nov 07, 2017 | Kodak EasyShare M575 Digital Camera
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
My camera cannot turn on or off is only 3 months old tried what might be the problem? i tried to charge the battery nothing happened i tried to take the battery out and back on still it did not work. i...
1. Remove the batteries from the camera and the memory card
2. Batteries should be Li-Ion Rechargeable Digital Camera Battery KLIC-7001 3. Verify batteries are inserted correctly
4. Place the camera in Auto Mode (Its green camera icon on the dialing mode)
5. Turn on the camera (if it failed try charging the camera)
6. Plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
a. If lights on battery charging light [solid green]
>charge the camera until light turns off or (up to 3hours)
b. If lights on battery charging light [red or flashing red]
>camera batteries are weak; replace with recommended batteries
c. If lights on battery charging light has [NO light]
>Try new set of supported batteries to test the camera one last time
>If already tested with a new set of batteries, set up the camera for repair
8. After all the step still camera will not work contact Kodak support line at 1 800 235 6325 (23KODAK) ** since the camera is less than a year it can be sent for repair in warranty. To receive warranty entitlement, you need to include a photocopy of the receipt or proof of purchase
NOTE: If Kodak repair center finds out customer induce damage, you will pay for the repair cost
Nov 19, 2009 | Kodak EASYSHARE M1063 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Kodak EasyShare V1003 Digital Camera Logo
73 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
