Question about Uniden BC796D Base Scanner
Uniden bc796d scanner will not communicate with PC
Need a manual for programing
check uniden web site should find info. JR
May 25, 2016 | Uniden BC796D Base Scanner
I'm not getting any reception on my scanner. Could you help me out?
it could be that your telescopic antenna that you got with your scanner could be Bad try putting another antenna on it. or try an outside base scanner antenna....
Jul 05, 2011 | Uniden BC796D Base Scanner
How do i program a apco 25 freq into the scanner
Just program a p-25 apco into a regular channel of your scanner... in your conventional scan mode...Just go to a certin channel of your scanner and program it in and it will automatically come in the APCO -P25...I have one of these scanners....ITs a wicked scanner...a good one...
May 02, 2011 | Uniden BC796D Base Scanner
I need the codes for monroe police , I have a digital scanner
For a comprehensive database of active frequencies in your area (they're not codes), and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Feb 21, 2011 | Uniden BC796D Base Scanner
Bc796d bank 9 issues
because all of your banks are locked out....
Feb 07, 2011 | Uniden BC796D Base Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Nov 11, 2010 | Radio Communications
I want to reset all data
www.uniden.com/pdf/BC796Dom.pdf -
Above is your manual and below is your support site, use these to do as you want, it is all explained in the manual, if you get stuck, contact them direct.
http://www.uniden.com/products/productdetail.cfm?product=BC796D
Jul 10, 2010 | Uniden BC796D Base Scanner
Cant find police numbers in northeast arkansas to program in scan
For a comprehensive database of active frequencies and systems in your area, visit:
Bill B
Apr 27, 2010 | Uniden BC796D Base Scanner
Uniden BC796D Base Scanner Logo
49 people viewed this question
Top Uniden Radio Communications Experts
Jason
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
