Question about Saeco Royal Professional Espresso Machine
Extra part I've owned a Saeco Royal Professional for just over a month now. Yesterday when removing the brewing unit to clean it in the sink.  After cleaning, I noticed that a small plastic part had come from somewhere and I don't know where.  It is cylindrical, 14 mm long, 12 mm in diameter with a hole in the center.  One end has a deep notch in it and has a smaller diameter than the other end.  The only place I could see that it may have come from is a cylinder on the back side of the brewing unit.  I tried it with the notch side down, but no water was able to get to the coffee.  Everything else worked fine -- coffee grinder, coffee ground dumper. I'm reluctant to try putting the mystery object in with the notch side up in case something breaks.   Any ideas? ERic
Eric...do you have a photo of the part?
Paul
Posted on Dec 15, 2007
I have a Saeco Royal Professional bought in 2001. It has been an awesome machine. I changed the boiler in 2005 and replaced the O-rings in 2009. It has been decalcified fairly regularly. Last month, I...
Hi
Sorry to tell you but Brew Unit Block is usually the CPU or the main board going bad. It is usually caused by a constant drag on the brew unit causing more power going to the drive motor causing the CPU and the main board to heat up weaking the CPU or main board to the failure point. To much coffee going into the brw unit and causing the brew drive motor to work harder to compress the coffee will also do the same. You will have to replace the CPU or the main board. It is usually the CPU.
Mar 31, 2011 | Saeco Royal Professional Espresso Machine
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
HI
There is a lever on the top of the door that has a + to the back and a - to the front. Pull the lever back 1 click to the front or - side. Your putting too much coffee in the brew unit and could break the brew drive.
Nov 30, 2009 | Saeco Royal Professional Espresso Machine
The machine makes funny noises at start up then no water goes through the brew group.
The brew unit needs to be lubricated, and the shower screen needs to be cleaned.
Nov 21, 2009 | Saeco Royal Professional Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Saeco Royal Professional capuccino maker brew unit assembly issue
Try this, check brew unit on it you will see a small arrow, this has to be pointing at the letter N, whisch is near the handle. Remove the drain tray and dreg tray, check the rails for the brew unit make sure there is no coffee on it, then slide unit in place.
May 27, 2009 | Saeco Royal Professional Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Coffee ends up in the bin not into the cups. What has happened and where can I go to resolve it. Thanks Mala
If you mean the Coffee Seems to end up all around your brew unit, a common fix is to move the dosage control (this is the slide on the right hand side of your machine just above the door to the brew unit) back and forth repetitivly.
Try this
Paul
Aug 18, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Jan 11, 2008 | Saeco Royal Professional Espresso Machine
Loud clicking and no coffee
Looks like your brew drive gears may be stripped. You should have a professional look at it because some must be causing the struggle to happen.
Saeco Service and Parts
www.cerinicoffee.com
Nov 26, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
83 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
