Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Flashing green button
Need a manual on how to get to the caps
  • PamK Nov 03, 2007
    CAN YOU SEND ME A COPY OF THE SCHEMATICS TO FIX THIS PROBLEM? I HAVE THE REPAIR MANUAL BUT I NEED THE SCHEMATICS TO FIX. I HAVE THE SCHEMATICS IN A PDF FILE BUT, MY PRINTER WILL NOT PRINT THEM. THE SERVICE MANUAL PRINTED FINE.
    Genius:
  • 1,694 Answers
Four generic caps 1000mf/25v 105 degree (high temp) buy from
any electronic supply, replace inside DM module.......T.
Posted on Nov 22, 2007
HP laptop 6530S is not starting?
The caps lock button flashing is a code to tell you what the problem is.
Count the flashes and get back to me. They will pause between counts, but if it is one it just flashes slow.
Apr 04, 2014 | Computers & Internet
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Flashing green button, won't reset or turn on
You can get the complete service manual for your set at the following link and they will provide free support to help you do the repair and even send you the instructions with pictures on how to do the DM repair. Your set Is the V23 chassis mitsubishi and thats how you have to select the manual. V23. Heres the link they email the manual to you instantly.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Mitsubishi WS-55613 55" Rear Projection...
WD-65833 Flashing Green Light/Will not turn on!
its an easy repair however i would recomend not even attempting the repair without the service manual as the DLP chassis is completely incased and you will need the info just to get the chassis out , That will explain exactly how to disassemble. once disassembled there are 4 100uf capacitors that are causing the problem. If you would like the full service manual for your set let me know and I will post a link where you can get it emailed and they will provide free support to help you do the repair.
Mar 29, 2008 | Mitsubishi WD-65833 65" HDTV
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
