Question about Behringer (UCA202) Sound Card
Recording not right
Hi:
when I plugged my band's 5 mics into the mixer and the mixer into the uca202 and to my computer to record, I got a recording that was skipping or jumping a few seconds (like a broken CD that jumps a few seconds and keeps playing), it felt like the recording couldn't keep up; I must have done something wrong. Some tunes only had like 3-5 skips, but others like 15 or more. What can I do???
He said the 5 parts were mixed , and then the mixer output connected to the input of the UCA202, so that is just one input , there should not be a problem.
you could try ASIO4ALL, but iv got the UCA202 and the noise coming from it is terrible with cubase sx and logic 8......
Posted on Jun 02, 2008
    Novelist:
    Champion:
  • 382 Answers
Check the recording buffer latency on your recording software. And so you know, you should max your ram out with that soundcard. or have everyone record there parts in as, 5 ins is alot for a machine to process, especially if youre recording to 1 track..brutal, and the final recording will be real muddy.
Keep me posted.
Posted on Oct 28, 2007
SOURCE:
Hi i want to record guitar and vocals using my mz n510 what do i need
Just plug a mic into the mic input or the mixer into the line input. Watch your levels!
User manual http://www.minidisc.org/part_Sony_MZ-N510.html
May 01, 2012 | Sony Net MD Walkman MZ-N510 MiniDisc...
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
How do I record my cassettes into my PC
find a tape player/recorder than has the capability to connect to a computer connect your tape player/recorder to your computer open windows explorer navigate to the tape player open it then select the files you want to copy to your computer right click select copy then navigate to the place where you want them saved or you can select the files hold the muse cursor on them drag them to the place you want to save them and drop them into it
hope this helps
Nov 28, 2010 | Behringer (UCA202) Sound Card
How to connect mixer 100 fx to uca 202 and laptop
Just connect:
one output from 100fx to uca202 line in. Connect an output that corresponds what you want to get (e.g. if you're going to record something use record out or main out)
one line input from 100fx to uca202 line out.
the USB cable from uca202 to your laptop's USB port.
The solution is the same (in general) whatever mixer you may have.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"????????? ???????"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Dec 03, 2009 | Behringer (UCA202) Sound Card
I plugged a mic to my dell laptop but it isnt working, do i need a sound card?
No, if you have a jack to plug the mic into you have a soundcard. However the mic is probably muted in the mixer software. Go to the control panel, left click on sounds and audio, then click on the advanced button; this should open the mixer in the play back mode, at the top left of the mixer go to options and select properties, a new page will come up with a radio button showing playback or recording, switch the radio button to the recording list and check everything in the checkboxes including the mic and press ok. A new mixer should come up with your recording deviced, from here you can set your microphone device volume.
Jul 01, 2009 | Computers & Internet
Can't record vocals
You can use any mic you want but you have to go to the soundcard mixer and enable the source for recording from the recording properties. If you have a separate soundcard not the onboard one usually it will have it`s own mixer software so you open that up and set it to record from the microphone input if that`s where your mic is inserted. If you use the onboard sound card then go to control panel - sound and select the device you want and also set the recording source. In sonar you have to right click on the track in the left part of the screen. This brings up the properties for that track. The you select the sound card input and output for that audio track.
That shoudl solve your problem.
Of course you will get a much better result if you use a good mic plugged into a mixer or pre amp and send the source into the line in of your sound card and adjust the rest accordingly.
May 14, 2009 | Cakewalk Music Creator 4
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Hi i have an hp pavilion dv2000 lap top, i am trying to record my acoustic guitar into the comp. This lap has conexant high definition audio sound card inbuilt. However when i try and plug a microphone...
The mic may be muted on the computer. In XP, double click the volume control icon in the bottom right of the screen to get the mixer. If you don't see the microphone input, go to 'options' then 'properties' and place a check in the box to show it. Then make sure it is unmuted and the volume is up.
In Vista, right-click the volume icon and choose recording devices and make sure it is on and volume up.
Apr 23, 2008 | Computers & Internet
Behringer (UCA202) Sound Card Logo
332 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
