Question about Kenwood KR-X1000
KR-X1000 Power Problems
I have a Kenwood KR-X1000 that will power up for about 10 seconds and then shut off. The clip light flashes when it does this. Any ideas?? Are there any free schematics or service manuals on the internet for this receiver?? Thanks!!
  • 1 more comment
  • fmstereo Oct 26, 2007
    Not a chance to play anything. It shuts down about 5 seconds after power up. Not even enough time to engage the relay. Thanks for your help!!
  • crooper Nov 27, 2007
    I've got the exact same problem. Have had the thing in storage for years with the hope that some day I could get it fixed (for less than it would cost to get a new one). Although I know that I broke it -- I accidently hooked up another receiver to its speaker outputs (it was still hooked to the speakers when I was trying out the other receiver, doh).
  • Anonymous Mar 29, 2014
    I had this kenwood kr 9600 serviced by a professional.iwas starting to have problems with it not wanting to turn on.i manipulated the switch gently with a back and forth up and down motion until it came on.when I finally turned it off,it has refused to come back on.
  • 979 Answers
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Posted on Oct 25, 2007
The power amplifier stage fault ,,
and protection circuit shutdown system
Posted on Mar 12, 2008
KR-V6050 I cannot get audio to work on radio, video or any other setting. Also the red standby light stays on all the time, even when the power switch is turned off. Alan
Check the input / output connections are in the correct places. The red standby will stay on when the unit is off showing that it is ready for use. To confirm, turn the power off at the wall. The red light should go out after a few seconds.
Nov 20, 2016 | Kenwood Kr-v6050 Audio Video Stereo...
How to connect spekers
If it's your first time in this project, connecting speakers are not simple but you can learn fast. First of all, I don't know the type of speakers you have. Not all speakers are the same, even in sound they're not the same. Some sound superb, others sound just right and many sound like tin cans. Because you have a Kenwood KR-X1000, it looks like you have large speakers. To connect these large speaker you need high quality speaker cables, not cheaper low amp types. Cables for speakers are usually marked with a continuous colored line along one side the cable. This line is an orange color is the cable is 100% copper and is a clear plastic cable (you can see the braided or twisted wire inside), or it could be black plastic with a white or grey colored band on one side of the cable. The colored bands means it's positive side (+). Split the cable ends then splice about half inch and twist the exposed wire. If you have a soldering iron, solder the exposed twisted braids to make it into a single solid wire for easy insertion into the speakers.
Now, I don't know what speakers you have but it doesn't matter, as long as you are aware that there are three types of connections used to connect the wires to the speakers. One type is a snap-on, another type is a squeeze, insert the wire in and let go. This is like a clamp. Another type is the a bolt type with a hole in the shaft of the bolt. The head is usually a plastic but to hold the wire and it is the strongest. Let's say you have the bolt type used by many professional speaker makers and users. You simply unscrew the plastic nut until the hole is open, then insert the wire in the hole then screw the plastic nut back tight. do a light pull test to see if the wire might slip out. Remember that these speaker connectors are colored red and black and the wire with the colored line on sheath is positive, that is it goes into the red connector. Then on the other end of the cable bet some tape or a tie to say this is the left speaker and this is the right speaker, this is the rear speaker and this is the right speaker, so that when you connect them to the Kenwood, you will not have to check which cable goes where.
The same thing goes with the Kenwood wire connection. I am a Pioneer man, I know them well. But I just happen to know that Kenwood and many others are very similar in wire connections because I am close to a store that has these, so, it's easy for me to go there and learn the tricks of trade. However, when I was writing this, it was too late to go down and have a look and the Kenwood X1000. So, I can only say that if you looked behind the machine, you'll find it all easily set and you can't go wrong. The red is positive (+) and black is negative (-). If you have been able to wire the speakers as instructed above, then you are also able to wire the Kenwood amplifier. Split the cables and strip or splice a half inch to expose the stranded wires the twist them and solder to form a solid wire for easy insertion and to stop the little copper wires in the braid from separating themselves from the twisted group. Then insert the colored line of the cable into the positive (red) clamp, clip-on, or screw type connector, whichever your amplifier has. Insert the negative soldered wire into the black clamp, clip-on or screw type connector. Do the same with the others speakers wires, recheck the connections, paying attention to polarities and test. It should work without problems. Cheers.
Dec 15, 2014 | Kenwood KR-X1000
How to troubleshoot a kenwood kr 5600
These older tuner/amps have protection relays that when latching, are distinctly audible. Does the relay engage after approx. 10 seconds after turn-on? If not, check your speaker wires and/or speakers for issues. With all speakers (and wires) disconnected, the relay should still latch after turn-on. If not then you have an internal problem...likely a older pre-drive transistor that's bias is incorrect, which in turn causes bigger problems downstream.
Jun 01, 2014 | Kenwood Audio Players & Recorders
No power
One has to open her up and check for aged or swollen caps on the
power supply.
Sep 08, 2012 | Kenwood Audio Players & Recorders
I have a kenwood am fm receiver KR-794 home stereo component that will turn on for a second or two and then shut off. The standby light remains on....I was told that it could be a connection...just...
95% of the time this is caused by damaged outputs. Depending upon whether it uses separate transistors or integrated I.C. packs, the cost can vary significantly. In my shop for instance, the repair could range from $65 to $250. (I.C. packs usually cost about $75 each whereas transistors are usually less than $10 each).
Jun 27, 2011 | Audio Players & Recorders
My problem is i not can connect the speaker
Refer to the manual(s). Your unnamed speaker(s) may have special requirements (or not). Either way, the manuals are very helpful and a good place to start.
Register and download the manual for free at
Mar 24, 2011 | Kenwood KR-X1000
Will not shut down
If your computer has frozen and can't be shut down properly, you have to force it to power off.
Press and hold the power button for 10 seconds, it will turn off.
Dec 24, 2009 | Compaq Presario X1000 Notebook
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Kenwood VR-3090 Red light flashes above power when turned on
You may need to reset the microprocessor, the ownersmanual describes this process as Turn the Receiver OFF,UNPLUG the POWER CORD from the elecrical outlet,PLUG the RECEIVER back into the outlet while PRESSING and HOLDING hte POWER ON button, continue to HOLD the POWER BUTTON for a Second or two, Hope this works for you, if not a CLIPPING problem could be the source only if you set up new speakers or input source. GOOD LUCK
Feb 15, 2009 | Kenwood VR-3090
Kenwood KR-X1000 Logo
540 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
