But i forgot my id password
Follow the steps for retrieve/reset your password...
1. go to gmail home page.
2. click on need help below the sign in button.
3.click on i don\'t know my password.
4. Enter your gmail address.
5. Click on i don\'t know
6. You are asked to get a verification code on my phone: ••••••••••xxx
.then click on continue.
7. Now you have to enter 6 digit verification code texted to your mobile number that was registered to your gmail acoount.
8. Now enter new password.
thanks.
It was helpful to you?
SOURCE: Windows 2000 password recovery
Try to download hiren boot cd (look in google), boot from it, there is several programs that turn off the windows passwords. on the first boot change it. [email protected] icq 475653626
SOURCE: I'm unable to send files
Turn off e-mail scanning in your anti-virus program. It is a redundant layer of protection that eats up CPUs, slows down sending and receiving, and causes a multitude of problems such as time-outs, account setting changes and has even been responsible for loss of messages.
SOURCE: wi-fi is not working..while installing
Sounds
that the wireless adapter daughter board is either loose or failing.
First, we need to make sure it is making good contact with the laptop's
motherboard. In order to do this, we have to do the following:
1. Turn off the laptop & remove the battery.
2.
Look at the compartments in the bottom of the laptop. You should be
able to see 2 or 3 areas with small rectangular plates covering them.
These plates usually have one or 2 screws holding them in place.
3.
Check which one of those plates is the one which covers the wireless
adapter daughter board. When you find it unscrew its screws & remove
it.
4. Below the plate, there will be a small daughter board screwed
to the laptop's motherboard, with 2 thin wires attached to it (usually
one black wire & the other is a white wire). Gently, remove both
wires using a small flat screw driver to pull them out gently. Don't
forget to note down which wire connects to which connection point.
5. Unscrew the wireless adapter daughter board & remove it from its slot.
6.
Clean both the slot & the daughter board's terminal connectors
using a dry electric contact cleaner. You can purchase it at an
electronics store.
7. Leave the slot & the daughter board for a while to dry.
8. Re-place the daughter board back in the slot & screw it to the motherboard.
9. Reconnect the 2 wires.
10. Screw back the covering plate.
11. Put back the battery & turn on the laptop. Check if the problem was fixed.
If
this did not fix the problem, you will need to repeat the steps to
remove the wireless adapter daughter board & replace it with a new
one.
SOURCE: i have forgot my password
your have to provide the right answer for your private question on your gmail account. go to gmail.com and click forgot password - answer the security question
http://www.ebay.com/itm/Password-Removal...
