Question about GE JVM1653 Microwave Oven
My three second microwave
I have a 1300 watt microwave and have had it for couple of years. Lately it has started to turn off automaticaticaly after 3 seconds.
  • 2 more comments
  • Anonymous Jan 07, 2008
    My JVM1653 runs for 3 seconds then resets to prompt for time and date. The problem is getting worse.
  • Anonymous Jan 10, 2008
    My unit also after approx. 3 seconds shut down and request you enter time and date. this happens each time I press start. My system was installed by a certified GE technicians
  • Anonymous Feb 10, 2008
    GE JVM1653, runs for about 3 seconds, then turns off and needs to be reset with date, time, etc. Manufacture date on the inside ta is january 2005.
  • Anonymous Jan 08, 2009
    Just started - last night (once) and tonight (once). Cooks for 2-3 seconds, shuts off - and display goes all 'alien'. Needs time/date reset. JVM1653 - manufactered 2004.
    First GE OTC microwave - magnetron failure.
    Replace it with another (this one) because the mounting etc. was already in place.
    I'm questioning that decision right about now.
  • GE Master
  • 9,098 Answers
This is probably due to a defective or possibly loose magnetron.
If yours has loose mounting nuts / bolts or the wire mesh RF gasket was not installed or got pinched, that can also cause
this RF leakage interference inside the oven.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
If you or a friend decide to look into it, we have critical information on safety and disassemblyat our site,
linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 05, 2007
Sharp microwave kb-6002ls making buzzing noise
Someone would have to open the unit to "hear" where it is coming from, possible fan issue or even the power unit inside.
Dec 03, 2012 | Sharp KB-6002LS 1000 Watts Convection /...
Microwave started smoking when i turned it on
Unplug the microwave and take it out check if any food items were present before u put oat meal inside it.IF there in nothing then check for any wire leaks.The smoke may have been caused by leakages in the microwave wire.Check both the things
Dec 07, 2011 | Panasonic NNSD697S Stainless Steel 1300...
Microwave resets after start
See this FixYa solution. even if your model number is different.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 23, 2010 | GE JVM1650 1000 Watts Microwave Oven
Smeg Microwave SA-971C2
the door protection circuit needs attention, the door catches operate microswitches, but there is also a third which is a crowbar microswitch. if all three do not operate in the correct sequence then the safety switch or fuse will go.
Feb 18, 2009 | Smeg FMC24 850 Watts Convection /...
PANASONIC INVERTER MICROWAVE, 1300 WATTS
  1. Same exact problem
  2. I've noted 3 different ones with the same problem
  3. Panasonic has produced a lemon, north fixing
Mar 27, 2008 | Panasonic NN-T694SF Microwave Oven
My DANBY DMW744W 700 watts does not work?
What would cause the plastic turn table shaft plate holder in the center to ignite
Feb 22, 2008 | Danby DMW650 700 Watts Microwave Oven
Microwave turns itself off after a couple of seconds
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Jan 22, 2008 | Thermador MBYB Microwave Oven
The microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Oct 03, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1653 Microwave Oven Logo
65 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
