Question about Motorola Mobility RAZR V3i Cellular Phone
V3 outer screen
I just replaced the screen in my Razr and now the outer scrren doens't want to work. It lights up and everything but it doesn't show the time/ date etc. The inner screen works fine. Its like the phone thinks its always open. Please help.
  • 72 Answers
Re: v3 outer screen
There's a tiny magnet in the top of the flip, near the hinge.. try taking a small magnet and hold it over the keypad near the hinge, and see if it doesn't think it's closed, if that magnet didn't get put back in the flip, then the phone won't know it's closed.
good luck!
Posted on Oct 27, 2007
0 characters
3 Points
Inside screen on razor doesn't work
more then likely youll have to replace the screen,it isnt complicated ..but you have to be delecate..if youd like ill explain it.. just let me know
Mar 02, 2010 | Motorola Mobility RAZR V3
Screen doesn't work. only after sereval attempts
This is a known problem for Razr V3. I had a phone like it with the same problem four years ago... I bought another brand and put the V3 away..three years later the phone works perfectly but I have not used it since three years..only turned it on to see if the screen will come on. Get the phone repaired or buy a new one. this is common on a RAZR
May 28, 2009 | Motorola Mobility RAZR V3
Blank Screen
Remove the battery and SIM card, wait about 5 minutes and re-insert everything. If the screen shows up, well and good. If not, there is a problem with the display and you will need to get the device serviced.
Sep 06, 2008 | Motorola Mobility RAZR V3
Black screen
try replacing the LCD on the phone
Sep 04, 2008 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Razr screens
uasdriver - have the flexcable replaced on the phone,this will take care of the display issue that you are having.
Guest - the flexcable or the lcd needs to be replace , take the phone to a mobile service center and have them replaced it.
Mar 20, 2008 | Motorola Mobility RAZR V3
This worked for me - I had to do it several times because I never figured out whether to start with the phone "off" or "on".
Press # * and the "end call (red)" buttons simultaneously and hold for several sections. Then power phone off and back on. I read this was the equivalent of "safe mode" booting for a RAZR. My phone has performed flawlessly since I did this on the 6th of February!
Aug 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
101 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
