Question about Samsung SF-5100 Plain Paper Laser Fax
SF5100 DOES NOT TRANSMIT ALL THE TIME
MY MACHINE OCCASIONALY SENDS HALF A PAGE OR LESS OF DATA .  THIS HAPPENS WITH MORE THAN ONE RECEIVER
  • Anonymous Nov 26, 2008
    my machine stretches the images & the sender reports an error on their side resulting in the faxes being sent more than once . ECM is off . pickup roller ,seperation pad & adf pads are replaced.
  • 417 Answers
There maybe 1000's of reasons for this but the most common is that the ECM mode is turned on (ECM =Error Correction Mode) turn this off and try. There is one other common fault try doing a copy of a document and see if that come out ok. If you are getting the same fault the scanner unit is faulty and will need replacing.
Hope this helps and please rate me
Cheers
J
Posted on Dec 30, 2007
What do CTCSS and DCS means
CTCSS is a subaudio (<300Hz) tone that is broadcast when you transmit on a radio. If another radio is set to receive that tone, then the squelch will open and he will hear your transmission. Having said that, any other radio that does not have CTCSS set at all will also hear your transmission, so all it does is for the receiver to hear less of others talking. DCS is the same except that CTCSS sends out a continuous tone, DCS sends out a string of tones. This allows more "channels" to be allocated, but still ,everyone is using the same frequency
see:
CTCSS DCS
Jan 25, 2015 | Radio Communications
I HAVE A SHARP UX-A450 FAX MACHINE AND WANT TO EMPTY THE FAX MEMORY.
MEMORY IS FULL / SEE MANUAL (alternating messages)
The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages:
It is important to erase received messages after you listen to them to ensure
that the memory does not become full.
? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY.
? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY
IS FULL and SEE MANUAL will alternately appear in the display.
? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up.
? Press STOP if you want to cancel the entire transmission.
Nov 25, 2010 | Sharp Office Equipment & Supplies
Peoplel are sending me very imp. faxes and idk how to recive it..
If your printer has FAX capabilities. Good way to tell is if you have a phone number pad on the front of your printer.
You must have this connected to a phone line for it to receive a fax.
Setup the fax application through your installation CD that came with the Printer/fax machine. Often you set the fax machine to pick up after so many rings. This allows you to leave the printer/fax machine on and gives you time to answer BEFORE the fax machine does. If uncle Bob or Aunt Susie should call to say Hi!
Basically what is happening:
You turn on the Printer/Fax machine it sits idle waiting for a phone call.
Someone now sends you a fax using your phone number.
YOUR printer/fax machine is sitting there listening for the phone to ring.
Lets say you have your printer/fax machine setup to answer after 5 rings.
After 5 rings, your Printer/fax machine will pick up and listen for signal tones from the the other machine. If it gets these, it will "handshake" and send a confirmation fax tone. Then the data will be transferred and printed out on your machine or held in a fax program for you to print or save later.
It is critical that you do not pickup the phone too early or the two fax machines trying to communicate will fail.
If you do this, you will hear an awful squeal and a serious of tones.
You can often hang up quickly and the two machines will transmit again the handshake signals and resume business as usual.
Short answer:
Two fax modems are talking to each other over your phone line to transmit data.
and hope this is helpful.
Oct 04, 2009 | Canon MX310 Office All-In-One Printer
I can not transmit.
i had this problem with mine that i just got a month ago. i called garmin, they said send it in or return it and get a new one. I returned and got a new one today and it sends and receives perfectly. You need a new one.
Nov 10, 2008 | Garmin Rino 530 GPS Receiver
Print too low from top of page
1-either the paper is not picking up in time
2-you need to change setting or scale
check the manual
http://www.retrevo.com/s/samsung+sf5100+manual
check "paper settings"
Jan 24, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Send data over T5720 ?
Those radios were not designed to transmit data, and has no any port for it.
Jun 18, 2007 | Motorola Talkabout T5720 (7 Channels)...
Samsung SF-5100 Plain Paper Laser Fax Logo
115 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
