Question about Dell 810 All-In-One InkJet Printer
Help hi i was wondering how to incert a envelope # 10 size in the printer, thanks.
    Genius:
  • 1,142 Answers
Hi, solution for your envelope
10 envelopes The print side of the envelopes faces up.
The envelopes are loaded vertically against the right side of the paper support.
The stamp location is in the upper left corner and printed with landscape orientation.
NOTE: For Japanese customers: If you are mailing within Japan, the envelope can be printed with portrait orientation with the stamp in the lower right corner or with landscape orientation with the stamp in the lower left corner. If you are mailing internationally, print landscape orientation with the stamp in the upper left corner.
The paper guide rests against the left edge of the envelopes.
You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned.
Posted on Feb 09, 2008
Printer will ask did you load the correct paper or envelope? I touch yes or no and it displays: copy does not support envelope #10. Load a supported size of paper in the tray to continue.
If you are trying to use #10 envelopes and your printer says it does not support that size, you'll need to try a different size envelope--one that the printer supports. Consult the owner's manual.
Apr 21, 2016 | Office Equipment & Supplies
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
How to print both return address and to address on ?size 10 envelopes
Open Microsoft Office Word.
Open File > Page Setup > Paper size > Envelope #10 (in Office Word 2003)
or
Open Page Layout > Size > Envelope #10 (in Office Word 2007 / 2010)
Then type the address like usual typing and print it.
I've found website to do this manually, but I'm not sure what the printer is. You can check out in here :
How do I print on thicker paper, labels and envelopes?
Hope this help, and if you feel helped, RATE please !
Jan 19, 2011 | Lexmark Z600 InkJet Printer
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
I have an HP Photosmart C4180 all in one and would like to know how to print #10 and also wedding size envelopes. I have tried changing the orientation on the Properties tab and changing the envelope size...
Hello Friend,
When you want to print page # 10 please see below and for wedding card printer please select envelope size from printing prefrences menu.
Start>settings>controlepanel>printer>C4180>Properties>printing prefrenes.
Thanks,
Viju
Apr 03, 2010 | HP PhotoSmart C4180 All-in-One Color...
I am wondering how to print on an envelope. Can you help me do this? thanks
Both of the leader programs, Word and WordPerfect provide for envelope in their code.
But you must make sure you select the correct size envelope in both the "Page Setup" from the application as well as from the printer driver.
Don
Nov 24, 2009 | Dell 3000cn Color Laser Printer
How to address size #10 envelopes using HP C4280 printer?
Goto print and preferences then under paper size select envelope size 10. Line them up over their picture on the printer and voila. If you are using word there is an envelope creator under the file menu.
Apr 27, 2009 | HP Photosmart C4280 All-in-One InkJet...
Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing envelopes from gestetner 3502P
What size are the envelopes?
Envelopes have to be fed through the bypass. #10 envelopes are not recommended to run through the copier. There too small to feed through the fuser rollers and they will jam.
Sep 03, 2008 | Office Equipment & Supplies
How to print #10 Envelopes
How to copy/print onto envelopes.
Solution
Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
Nov 13, 2007 | Office Equipment & Supplies
Dell 810 All-In-One InkJet Printer Logo
222 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
