Question about Proview PL926WBi 19" LCD Monitor
Proview PL926WSi LCD monitor will not power up
I have a Proview PL926WSi LCD monitor that will not power up at all.
Been working fine for over a year then all of a sudden turned itself off and now I cannot power it back on.  There is no power light when it is plugged in, nothing.   At first I thought maybe the power board went out on it and ordered a replacement from Proview parts department.  $65 later and I just tried to plug it in and still not getting anything, no power light , nothing.   Any ideas?
  • 1 more comment
  • dhnguyen Oct 25, 2007
    Yes I did test it on another PC.  I should stated that previously.
    There is no power going to it that I can tell.
    Do LCD monitor power light only come on if the monitor is connected to a PC?
    I should add that I don't think it's the PC as another monitor works just fine on said PC.  Thanks
  • Anonymous Nov 15, 2007
    I Have a Gateway 900w with the same problem that you described....Cheap is not always better....After taking the junk Gateway LCD apart....the power supply had a blown capacitor....What do you do now? mmmm well time to trow it away and yes it is barely a year old, just enough to get out of warranty. Back to my original comment...even though you may not think it was cheap when you bought is made very cheap. An ACER LCD comes with an 3 year Warranty and only cost about $ cheap made not cheap cost...
  • 3 Answers
I have the same moniter here and it looks like they are blowing the C318 and C317 capacitor on the board
if i can fix this one here i may be able to fix your board if needed
Posted on Dec 07, 2008
  • 38 Answers
Try testing the monitor on another computer.
Posted on Oct 25, 2007
My moniter has a black screen and is blicking blue light. i have a proview model 2200w? Was working fine until i shut down yesterday. I unpluged, nothing happened. Could it be in a sleep mode? If so, how...
this is so common in lcd monitors, its the power suply board.... most likely a capacitor.. so type a model# into google following the words "power suply" it will probably be close to $50-$60... thats better than buying a new one
hope this helps you
Feb 06, 2011 | Proview PL576Ws 15.4" Widescreen LCD...
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Proview monitor PL926WSi Screen goes out after about 5 seconds
Hello Joe,
A red or pink coloration on the screen indicates bad backlight bulbs. They are just like standard fluorescent bulbs just much smaller. When they start failing they light up with a pink color and that will make the screen look pink or red. You can change them but it may not be worth the trouble. You can do a Google search for compact fluorescent tubes and check prices.
I hope this helps, if so please rate our solution.
Corporate Computer
Oct 18, 2009 | Computers & Internet
Proview monitor blacking out
i would suggest getting a new monitor you might have made it overheat or your display driver failed.
Feb 16, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
LCD Monitor goes off after 2 sec.
Check all cracked solder joints and resoldered and check two smd transistors near the inversors good luck
Aug 11, 2008 | Proview PL913B 19" Flat Panel LCD Monitor
Proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Oct 17, 2007 | Proview PL926WBi 19" LCD Monitor
Monitor works on one computer, but not the other
The problem is not your monitor, but the video card on your computer that it doesn't work on. If the video output on your computer is built in, residing near your keyboard / mouse ports, you can purchase another video card to put into your computer and connect your monitor up to that instead. If it attaches to a separate card inside your computer, just replace it. There are three kinds you can get, AGP, PCI, or PCIe. Make sure you get one that will fit inside your computer.
Jun 26, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
392 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
