OK ideas & to check:
is there water getting in through the rear doors as the inner door membrane is not watertight? if this is the case will need sealing.
Sunroof: if there is a sunroof check ducts are not blocked.
Tailgate lights: Is there water sloshing around inside any of the lights, as this may cause the water to breach their seal & run from boot under seat to footwell....
Is it just rear footwells or are the front wet too? if so check again ducts from sunroof as the hoses come out of the wheel arch. OR have you had new windscreen - poor fitting windscreen (even with the best intentions) causes it to leak. Or heater matrix (this will cause front wells to be wet & will run backwards: check your water levels in expansion tank, if it looses water could be faulty matrix. IF leak is rain water it tastes different to the water / antifreeze in tank...
Hi elizabeth jupp, do you have a sunroof, n have you taken carpets up to see if there is staining from say bottom of doors down?
