Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F2 light flashing with a picture of a wrench and don't work
  • Anonymous Nov 18, 2007
    F2 but it is only the top draw it seem there is no water getting to the draw
  • tim66 Jan 01, 2008
    bottom drawer will start and then within 1 minute it will make a whirring noise and the f2 with wrench flashes and machine stops.
  • 92 Answers
F2 is a motor fault try taking the motor from the other draw and see if that works if so needs motor if not then you probobly need a hall sensor
Posted on Jan 20, 2008
Lights flashing and wrench symbol lit
Don, It is telling you maintenance/service is required, contact a technician to have a look.
Apr 17, 2016 | Health & Beauty
My acer Aspire 3500 wont turn on. It was fine a few hours ago but now wont boot. I keep getting the acer picture featurning the f2 set up and then the screen turns blank with a white flashing - in the left...
if you activity lights on, try connecting to an external monitor or modern flat screen tv. if the screen is flashing then it is probably a screen issue. eg the invertor r screen has failed.
Jul 23, 2011 | Computers & Internet
My 2001 Saturn L200 service light with the wrench keeps coming on. If I drive about 100 miles and park the car when I return to start it that is when the light comes on not while driving. I can not get the...
Service (Wrench) System Check The SERVICE (Wrench) telltale is turned ON by the cluster when it receives a command from the powertrain control module (PCM) or the body control module (BCM). The PCM or BCM will turn the SERVICE (Wrench) telltale ON for all non-emission related diagnostic trouble codes (DTCs) that require that a telltale be turned ON, some DTCs do not turn ON a telltale but are stored to aid in diagnosis.
The SERVICE (Wrench) telltale will also be turned ON if the Antilock Brake System (ABS) control module has detected a fault in its own warning indicator system. If the ABS cannot turn ON its own telltale, a message will be sent to the BCM through the Key Word 2000 data bus to turn ON the SERVICE (Wrench) telltale.
The SERVICE (Wrench) telltale will be turned ON by the cluster for 2-3 seconds, when the ignition is turned to RUN, for a visual system check.
You need to have codes checked .
May 07, 2017 | Saturn L-Series Cars & Trucks
How do I set the Iso and flash
ISO is the sensitivity to light. The lower numbers 80, 100, 200 are the LEAST sensitive (but provide the best looking pictures). Sensitivity has to do with the amount of light needed to properly expose an image. ISO is a part of exposure that works with Aperture (f stop) and shutter speed (in seconds - or fractional seconds). Here's how it looks:
The graphic above shows that varying either of these three values changes the exposure. If you change one by one step, you have to change one of the others by one step to get about the same exposure result. Each of the step values on your camera for the shutter, aperture and ISO is twice as much as the previous value. ISO 1600 is 2x ISO 800, which is 2x ISO 400, and 2x ISO 200 and finally, 2x ISO 100 (some cameras go to ISO 50 or less!).
The shutter works the same way: 1/1000 is 2x faster than 1/500, and 2x 1/125, and 2x 1/60, and 2 x 1/30, etc. These are easy to see the how each is twice as much as the other.
Finally, the aperture. Each "f stop" allows 2x as much light as the previous value. f2 lets 2x as much light as f2.8, which lets in 2x as much as f4, etc. I know the number don't double like you would expect, and the smaller numbers allow more light (you'd think it was the other way around) - but it's because we're talking about a circular lenses and it has to do with how we calculate area of a circle (3.14 x R squared). It may be easier to recall small numbers = equal large openings by thinking of f numbers with a "1/" over them - like this: 1/f1.4, or 1/f2, 1/f2.8, etc. Here's a chart that shows how aperture and shutter speed work together at one ISO setting.
Read them across, the top line shows that 1/250 @ f1.4 is the SAME as 1/125 @ f2.0, which is also the SAME as shooting 1/60 @ 2.8, etc. If you were to increase the by one step, the shutter speeds would increase by a factor of two. Twice as much light by opening the aperture by a single stop means you must halve the exposure time or halve the ISO value. Likewise, if it's too dark to get a decent picture; increase exposure time or ISO value to capture enough light.
Assume a properly exposed picture requires 1/30 of a second at f5.6 with ISO 200. If the camera was increased by one step to ISO 400, you can take the picture a f5.6 still but in 1/60 sec - greatly reducing the chance of blur from holding the camera in you hand. You could even go up one more step to ISO 400 and shoot in 1/125 sec, which would reduce the blur even more. Fast shutter speeds reduce the "camera shake" and stop motion in sports photography - or other moving objects. If you had the camera set up on a tripod, you could dial the ISO down to ISO 100 and shoot at 1/30 of a sec at f5.6. If your lens can open up to f4, you can shoot in half the time because the lens is letting in twice the light. Some point and shoot cameras don't allow changing f stops or even shutter speeds - so all you can do it raise and lower ISO.
Which camera and flash do you have?
May 23, 2011 | Cameras
My ds wont charge the orange lite wot turn on and the charger slot on my ds is wied looking
my ds lite wont charge i get a flash of the orange light then nothing can you help me please
Jan 05, 2010 | Nintendo DS Lite Console
Samsung S730 No Flash
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Jan 18, 2008 | Samsung Digimax S730 Digital Camera
F1 light flashing with a picture of a wrench
See http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm, or http://www.fixya.com/support/t103415-fisher_paykel_dd_603_dish_drawer
Aug 24, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
229 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
